ASA CX module CLI Problem.
jitesh.mahajan
Dear Support,
I am having the ASA 5515 and in this ASA CX module install for contain filtering.
I have configure the some policy in CX module through PRSM GUI.
I also enable ssh for CX module. My CX module is not have any problem all my policies are working fine.
But when i am login from SSH I am not understand how to see the running config in CX module through CLI.
because i tried all show commands and i am not find any running config of the policy commands.
Please suggest which command is helpful to see the running config of CX module through CLI.
And if you have output of show run of CX module please post.
Thanks in Advance.
JItesh Mahajan.
Marvin Rhoads
The policies applied from PRSM to the CX module is not displayable from the CX CLI. They can only be displayed from the PRSM GUI.
The CX CLI will only show you the basic setup configuration (interface ip address, default gateway for management etc.)
