ASA Failover Problem
piotr.chrusciel
Visitor
During Active/Standby Failover set up I came across a problem. I have two ASA 5510 and two CSC-SSM modules. We bought the first pair some time ago and we decided to configure failover. After configuration replication from Active to Standby  - the Standby switched to Failed State. I had no idea what it was going wrong. Istead CLI I tried configuration using Wizard, and I received an info that the compatibility of modules was the issue.
Old ASA
Mod Card Type                                    Model
0 ASA 5510 Adaptive Security Appliance         ASA5510
1 ASA 5500 Series Content Security Services Mo ASA-SSM-CSC-10-K9
Old ASA
Mod Card Type                                    Model
0 ASA 5510 Adaptive Security Appliance         ASA5510-K8
Possibly modules names do not match. Is there a way to change them? Maybe firmware upgrade? Any suggestions?
Panos Kampanakis
Please request TAC to help you out with this in a case.
I hope it helps.
PK
unfortunatelly client did not buy service contract for new ASA and CSC. Is there a possibility to send TAC request without service contract?
Pls check if the ASA and CSC are still under warranty. Otherwise, you would need to purchase Smartnet contract prior to opening a TAC case.
