ASA HSRP and failover mode issue
prem.ce24
Hello Team,
1 issue:-> I have 2 cisco asa5585 when i have configuration regular failove link between these 2 asa management IP address of secondary asa aslo changing to as primary asa mgmt ip address i need separate mgmt ip address for both asa but both asa also need to configure in failove mode.
So please suggest solution for same.
2 issue:-> is it possible to configure hsrp between to asa interface in failover mode.
Please suggest solution for same also.
Thanks & Regards,
Prem Prakash
Boris Uskov
Level 4
Level 4
1 issue. If I understand the question correct, you need to have separate IP-addresses on Management interfaces of ASAs. If so, you need to configure on Active ASA according to the following example
interface Management0/X
ip address 172.16.1.1 255.255.255.0 standby 172.16.1.2
So that the Active ASA will be available on Management interface through 172.16.1.1 and Standby ASA through 172.16.1.2.
2 issue: HSRP is not supported by ASA. But if you have Active/Standby failover, what is the purpose of HSRP between ASA's interfaces?
Boris Uskov
Level 4
Level 4
Thanks for Support
