ASA in transparent mode with LAN based Active/Standby Failover?
NotMeHere
Is it possible to have a pair of ASA's in transparent mode with LAN based Active/Standby Failover? I configured the failover portion, then configured transparent mode and it erased my failover configuration. Is this configuration supported, and if so is there an example?
Thanks in advance
prasadrp
Yes. It is possible to have a pair of ASA in transparent mode with LAN based Active/Standy failover. You should do the failover configuration after converting the appliance into transparent mode.
I haven't seen any example on cisco site, but I will give you example from one of the project which I executed. Infact its very easy to configure failover in transparent mode. Less work.
I have listed the configs on both the firewall for your reference
Primary Firewall
interface GigabitEthernet0/0
nameif outside
security-level 0
no shut
interface GigabitEthernet0/1
nameif inside
security-level 100
no shut
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
interface GigabitEthernet0/3
description LAN Failover Interface
ip address 192.168.9.2 255.255.255.0 standby 192.168.9.7
failover
failover lan unit primary
failover lan interface FAILINT GigabitEthernet0/3
failover key abcdef
failover interface ip FAILINT 172.16.9.1 255.255.255.0 standby 172.16.9.7
On Secondary Firewall
failover
failover lan unit secondary
failover key abcdef
int GigabitEthernet0/3
no shut
Hope the above helps.
5 Replies 5
prasadrp
Primary Firewall
nameif outside
security-level 0
no shut
nameif inside
security-level 100
no shut
shutdown
no nameif
no security-level
failover
failover key abcdef
failover
failover key abcdef
no shut
That did the trick! Thanks, it worked perfectly.
I am a little confused about transparent mode with failover. To explain my confusion, let's take the scenario of routed mode where you want to configure an inside router to an internet router and the PIX failover bundle is in the middle. In this instance, you would configure two VLAN networks on a switch and connect the (2) PIX inside interfaces and the inside router to VLAN1 and would connect the (2) PIX outside interfaces and the outside router to VLAN2
How would you accomplish the above if you are doing transparent mode?
Thank you
quick question.
i configured failover with transparent mode and it seems to work fine when the active box goes down.
but have you tried this with a 'monitor-interface' scenario, where usually if one of the interfaces on the active pix (or asa) goes down, the standby pix becomes active?
i know that a monitor-interface scenario is somewhat L3 based, so a pix routed mode comes in handy. but i've been trying to get this to work and the active pix, just won't failover.
regards,
c.
Hello, i did almost the same configuration but i have one problem when i tried use the ASDM by web or soft, always request the password, never work.
Did you had any problem with the console administration in this mode(transparent)?
