ASA inside hosts : Security Plus or not ?
ComstorFR
Level 3
Level 3
I want to  upgrade  "inside hosts" from 10 to unlimited on a ASA5505-BUN-K9,
Do I have to buy  Security Plus license ( L-ASA5505-SEC-PL 😃  ) before activating ASA5505-SW-10-UL ?
Best regards
2 Accepted Solutions
Collin Clark
When you purchase the license, you'll get an email with a PAK. You then go to the Cisco website, enter your PAK and you will an upgrade key that you enter into the ASA and it will update the user count.
varrao
Level 11
Level 11
Here's you're answer:
http://www.cisco.com/en/US/partner/docs/security/asa/asa82/license/license82.html#wp190062
You don't need the security plus license, but just the license for unlimited hosts.
Hope this helps.
Varun
Please rate helpful posts
Varun Rao
Collin Clark
varrao
Level 11
Level 11
Hope this helps.
Varun
Varun Rao
ComstorFR
Level 3
Level 3
Thank a lot both Collin and Varun for yours answers
regards
