ASA- Interface monitoring is not triggering the failover
sfarazaz123
Hi all,
I am testing Cisco ASA H-A with our ACI switches. i m using port channel on ASA + vPC on the ACI switches.
I have two port channels
1) data --> inside and outside with sub-interfaces as po1.114 and po1.115 for example
2) failover --> po2 (g1/7 and g1/8).
Each p channel has two physical interfaces bundled together. Every thing is working fine in failover setup. I m monitoring the inside and outside interface. The issue i m setting is that when i shutdown the inside subinterface on the active firewall no failover occurs same for outside sub-interface as well. i wait for 5 minutes but nothing happen. the interface poll time is default configured. 5 and 25 sec but nothing happen.
what i want is
when inside or outside subinterface is down failover should occur. also when i shout down complete port channel it should also failover.
I need you help to configure it correctly. Let me know what config you would like to see for that.
I read in the documentation that physical interfaces are monitored by default but not the sub-interfaces. Is that mean if i shutdown both interfaces (i.e. g1/1 and g1/2) in the po1 than failover occurs ?
Thanks in advance.
Best Regards
far
0 Replies 0
