ASA multicontext in active active mode problems
teymur azimov
Level 7
Level 7
Hi Dear Cisco team,
In my network have a lot of different subnets and in security cases some of subnets must be access to others and some of them are not. In network  have 2 Cisco catalyst 6513 switch which use core device and have 2xASA 5525 which are use internal firewall and access switch catalyst 3750 which is use floor switch.
I want to grouped some subnets(Vlans) so I configurate multicontext in ASA and configurate ASA in active active mode. So some vlans include in some contexts in ASA1 (this contexts are active In ASA1) and other contexts in ASA2(that conetxts are  active in ASA2). I use Eigrp dynamic routing protocol in ASA's. In ASA's the new IOS 9.1. ( as you know eigrp is working in multicontext active active mode).
As you know the in default the contexts are not access each other so i decide to use vrf-lite for this in Core switch.
traffic flow(logicaly): the users default gateway are ASA's. The packet is coming from users to internal ASA then go to core switch.
For example; 10.30.40.0 subnet is in ASA1 in active context and i  want to access 10.30.44.0 subnet in ASA2 active context.
when i do ping from 10.30.40.10 user (ASA1 context: C1(active) to 10.40.44.10 (ASA2 conetext:C2 active) user.  The ping is not going.
The active active mode failover is working. when i turn off the ASA2 the all traffic is pass thougth the ASA1 and in this case C2 is active in ASA1 and in this time i can ping form C1 to C2 . In ASA1 different contexs are working.
The problem is in active active mode in different contexts are not working.
I attach logical and physical topology and configuration files of devices and routing tables of devieces.
please help.
I attach 6513 configuration file.
p vrf asa
rd 65515:1
route-target export 65515:1
route-target import 65515:100
route-target import 65515:101
ip vrf mapas
rd 65515:100
route-target export 65515:100
ip vrf mapas1
rd 65515:101
route-target export 65515:101
interface GigabitEthernet1/1/2
description connecte_to_ASA_outside
switchport
switchport access vlan 1000
switchport mode access
speed 100
interface GigabitEthernet1/1/3
description connect-to-Router-outside
switchport
interface Vlan340
ip vrf forwarding mapas
ip address 10.30.40.254 255.255.255.0
interface Vlan344
ip vrf forwarding mapas1
ip address 10.30.44.254 255.255.255.0
interface Vlan1000
ip vrf forwarding asa
connection ASA_outside_interface
ip address 10.100.100.254 255.255.255.0
router eigrp 2008
address-family ipv4 vrf mapas
  redistribute connected
  redistribute bgp 65515 metric 128 10000 255 1 1500
  network 10.30.40.0 0.0.0.255
network 10.30.41.0 0.0.0.255
network 10.30.42.0 0.0.0.255
network 10.30.43.0 0.0.0.255
autonomous-system 2008
exit-address-family
address-family ipv4 vrf mapas1
  network 10.30.44.0 0.0.0.255
network 10.30.45.0 0.0.0.255
network 10.30.46 0.0.0.255
exit-address-family
address-family ipv4 vrf asa
  network 10.100.100.0 0.0.0.255
exit-address-family
router bgp 65515
bgp log-neighbor-changes
redistribute eigrp 2008
exit-address-family
exit-address-family
exit-address-family
Router:
CORE-VSS#show ip  bgp vpnv4 all
BGP table version is 674, local router ID is 172.31.40.105
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
              x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
     Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 65515:1 (default for vrf asa)
*   10.30.40.0/24    10.30.44.1            2816         32768 ?
*>                   10.100.100.1          2816         32768 ?
*                    0.0.0.0                  0         32768 ?
*   10.30.41.0/24    10.30.44.1            2816         32768 ?
*                    0.0.0.0                  0         32768 ?
*   10.30.42.0/24    10.30.44.1            2816         32768 ?
*                    0.0.0.0                  0         32768 ?
*   10.30.43.0/24    10.30.44.1            2816         32768 ?
*                    0.0.0.0                  0         32768 ?
*>  10.30.44.0/24    10.100.100.3          2816         32768 ?
*                    10.30.40.1            2816         32768 ?
*                    0.0.0.0                  0         32768 ?
*>  10.30.45.0/24    10.100.100.3          2816         32768 ?
*                    0.0.0.0                  0         32768 ?
*>  10.30.46.0/24    10.100.100.3          2816         32768 ?
*                    0.0.0.0                  0         32768 ?
*>  10.30.47.0/24    0.0.0.0                  0         32768 ?
*>  10.30.48.0/24    0.0.0.0                  0         32768 ?
*>  10.30.49.0/24    0.0.0.0                  0         32768 ?
*>  10.30.50.0/24    0.0.0.0                  0         32768 ?
*   10.100.100.0/24  10.30.40.1            2816         32768 ?
*                    10.30.44.1            2816         32768 ?
*>                   0.0.0.0                  0         32768 ?
Route Distinguisher: 65515:100 (default for vrf mapas)
*                    10.100.100.1          2816         32768 ?
r   10.30.44.0/24    10.100.100.3          2816         32768 ?
r                    10.30.40.1            2816         32768 ?
r>                   0.0.0.0                  0         32768 ?
r   10.30.45.0/24    10.100.100.3          2816         32768 ?
r   10.30.46.0/24    10.100.100.3          2816         32768 ?
*>  10.100.100.0/24  10.30.40.1            2816         32768 ?
*                    0.0.0.0                  0         32768 ?
Route Distinguisher: 65515:101 (default for vrf mapas)
*>  10.30.40.0/24    10.30.44.1            2816         32768 ?
*                    0.0.0.0                  0         32768 ?
*>  10.30.41.0/24    10.30.44.1            2816         32768 ?
*                    0.0.0.0                  0         32768 ?
*>  10.30.42.0/24    10.30.44.1            2816         32768 ?
*                    0.0.0.0                  0         32768 ?
*>  10.30.43.0/24    10.30.44.1            2816         32768 ?
*                    0.0.0.0                  0         32768 ?
*   10.30.44.0/24    10.100.100.3          2816         32768 ?
*   10.30.45.0/24    10.100.100.3          2816         32768 ?
*   10.30.46.0/24    10.100.100.3          2816         32768 ?
*>                   10.30.44.1            2816         32768 ?
*                    0.0.0.0                  0         32768 ?
CORE-VSS#show ip route vrf mapas
Routing Table: mapas
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is not set
      10.0.0.0/8 is variably subnetted, 20 subnets, 2 masks
C        10.30.40.0/24 is directly connected, Vlan340
L        10.30.40.254/32 is directly connected, Vlan340
C        10.30.41.0/24 is directly connected, Vlan341
L        10.30.41.254/32 is directly connected, Vlan341
C        10.30.42.0/24 is directly connected, Vlan342
L        10.30.42.254/32 is directly connected, Vlan342
C        10.30.43.0/24 is directly connected, Vlan343
L        10.30.43.254/32 is directly connected, Vlan343
D        10.30.44.0/24 [90/2816] via 10.30.43.1, 00:13:51, Vlan343
                       [90/2816] via 10.30.42.1, 00:13:51, Vlan342
                       [90/2816] via 10.30.41.1, 00:13:51, Vlan341
                       [90/2816] via 10.30.40.1, 00:13:51, Vlan340
D        10.30.45.0/24 [90/2816] via 10.30.43.1, 00:13:51, Vlan343
D        10.30.46.0/24 [90/2816] via 10.30.43.1, 00:13:51, Vlan343
B        10.30.47.0/24 is directly connected (mapa1), 00:16:34, Vlan347
L        10.30.47.254/32 is directly connected, Vlan347
B        10.30.48.0/24 is directly connected (mapa1), 00:16:34, Vlan348
L        10.30.48.254/32 is directly connected, Vlan348
B        10.30.49.0/24 is directly connected (mapa1), 00:16:34, Vlan349
L        10.30.49.254/32 is directly connected, Vlan349
B        10.30.50.0/24 is directly connected (mapa1), 00:16:34, Vlan350
L        10.30.50.254/32 is directly connected, Vlan350
D        10.100.100.0/24 [90/2816] via 10.30.43.1, 00:16:00, Vlan343
                         [90/2816] via 10.30.42.1, 00:16:00, Vlan342
                         [90/2816] via 10.30.41.1, 00:16:00, Vlan341
                         [90/2816] via 10.30.40.1, 00:16:00, Vlan340
CORE-VSS#show ip route vrf mapas1
Routing Table: mapas1
      10.0.0.0/8 is variably subnetted, 19 subnets, 2 masks
D        10.30.40.0/24 [90/2816] via 10.30.46.1, 00:14:36, Vlan346
                       [90/2816] via 10.30.45.1, 00:14:36, Vlan345
                       [90/2816] via 10.30.44.1, 00:14:36, Vlan344
D        10.30.41.0/24 [90/2816] via 10.30.46.1, 00:14:36, Vlan346
D        10.30.42.0/24 [90/2816] via 10.30.46.1, 00:14:36, Vlan346
D        10.30.43.0/24 [90/2816] via 10.30.46.1, 00:14:36, Vlan346
C        10.30.44.0/24 is directly connected, Vlan344
L        10.30.44.254/32 is directly connected, Vlan344
C        10.30.45.0/24 is directly connected, Vlan345
L        10.30.45.254/32 is directly connected, Vlan345
C        10.30.46.0/24 is directly connected, Vlan346
L        10.30.46.254/32 is directly connected, Vlan346
C        10.30.47.0/24 is directly connected, Vlan347
C        10.30.48.0/24 is directly connected, Vlan348
C        10.30.49.0/24 is directly connected, Vlan349
C        10.30.50.0/24 is directly connected, Vlan350
D        10.100.100.0/24 [90/2816] via 10.30.46.1, 00:14:36, Vlan346
teymur azimov
Level 7
Level 7
Can someone help me from Cisco?
Thanks.
I think it would be best to open a ticket with TAC since they can use collaborations between routing and ASA teams. Also you need to be more specific, I believe that what you are talking about is the concept of cascading but you need to give out details of what context and what traffic you are originating from the test PC that indicates that when traffic is set on one ASA it works fine but when having both units running active/active mode it does not.
Value our effort and rate the assistance!
