ASA Port Forwarding Issue
robert3kennedy
Hi, Im looking for a bit of assistance, Im pretty sure im making a silly mistake somewhere.  I am trying to allow port 3389 through ASA to a host for RDP.  I will eventually tie it down so it can only be accessed from one location.
ASA Version 9.8(2)38
ASDM Version 7.8(1)
Screenshots of NAT and ACL rules attached.  It is failing the packet tracer on the ASA at the NAT section.
Any help appreciated.
16 Replies 16
so the translation seems to be in place. But not in a way that corresponds to your above config. In your nat-statement you have
nat (INSIDE,OUTSIDE) ...
and the XLATE should read
TCP PAT from INSIDE:192.168.50.50 3389-3389 to OUTSIDE:217.39.144.61 3389-3389
And the packet-tracer should list the UN-NAT in Phase 2 (an example from my ASA):
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
object network WIN-SERVER
 nat (inside,outside) static interface service tcp 3389 3389
Additional Information:
NAT divert to egress interface inside
Untranslate 192.0.2.100/3389 to 10.1.1.21/3389
In this working scenario, my NAT-statement, XLATE, and packet-tracer-command are the following. Compare that to your config and testing:
 host 10.1.1.21
TCP PAT from inside:10.1.1.21 3389-3389 to outside:192.0.2.100 3389-3389
packet-tracer input outside tcp 1.2.3.4 1234 192.0.2.100 3389
TCP PAT from INSIDE:192.168.50.50 3389-3389 to OUTSIDE:X.X.X.X 3389-3389
is now how the XLATE presents,
However, when running the packet trace, still no change, and no UN-NAT at phase 2
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
found next-hop X.X.X.X using egress ifc identity
Phase: 3
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 4
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: OUTSIDE
input-status: up
input-line-status: up
output-interface: NP Identity Ifc
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Current relevant config
object service RDP
service tcp destination eq 3389
description RDP
object network RDP_HOST
host 192.168.50.50
nat (INSIDE,OUTSIDE) static interface service tcp 3389 3389
