ASA port forwarding not working. Help ?
Diogene
Hello everybody. Could someone help me with this running-config. I would like to do port-forwarding with my AS5506W. My private server is on 10.10.30.2.
Find below my running-config on ASA. I have done all that is the running-config but it is still not working. I know I have some repeated NAT and ACL. Can you tell me what is wrong ?
Diogene
I followed this tutorial for ASDM : https://www.youtube.com/watch?v=cKnAiiUgsgg
It works well.
In running-configuration :
object network NAS-host
 host 10.10.50.2
object service NAS-service
 service tcp source eq 4480
nat (INT-WIFI-PERSONNEL,outside) source static NAS-host interface service any NAS-service
access-list outside_access_in extended permit tcp any object NAS-host eq 4480
access-group outside_access_in in interface outside
Thank you very much for your help.
8 Replies 8
balaji.bandi
Your intention to port-forward only specific ports or any ? ( your config required lot of cleanup, why there is BVI Interface ? and inside_X interfaces)
here is the syntax you have - add host should work,
object network NAS-TEST
host 10.10.30.2
nat (INT-NAS,outside) static interface service tcp 4480 4480
if not post
#show run access-group
BB
Only in specific port : 4480.
above should work, try and advise
if not working post packet trace output.
BB
 host 10.10.30.2
access-list OUTSIDE_IN extended permit tcp any object NAS-TEST eq 4480
access-group OUTSIDE_IN in interface outside
basically, you missing the access-list from outsider interface. do a packet tracer it will work now.
please do not forget to rate.
OK. I have this in my configuration :
access-list outside_access_in extended permit ip any any
It's not enouth as permission ?
do not use "permit ip any any" at outside as your network will be at secuirty risk.
no access-list outside_access_in permit ip any any
access-list outside_access_in extended permit tcp any host 10.10.30.2
object network NAS-TEST<- delete this
nat (INT-NAS,outside) static IP  service tcp 4480 4480<- add this
please make change as above.
Diogene
It works well.
 host 10.10.50.2
