ASA Problem - Maximum message size
gtuhindhaka
Community Member
Dear All,
When i am trying to access one server which is above my ASA i am getting the following error.
Dropping TCP packet from Outside:10.20.8.52/30000 to Inside:10.20.0.243/34538, reason: MSS exceeded, MSS 1380, data 1436
In ASA under TCP options check mark is set at "Force maximum message size for tcp proxy connection to be 1380 bytes.
If a uncheked the option then i can access that server. But from outside some html pages can't be accessed which are inside my ASA.
What to do sir.
Tuhin
Dhaka, BD.
