ASA SLA Monitoring on same interface?
jason.henderson
Hi all,
I'm trying to get the config below to work on an ASA, but it just installs the backup route in the routing table and never uses the tracked route - does sla monitoring work when the tracked and backup route are both out the same interface? Everything seems to be working, e.g. pings to tracked object etc. -
route outside 10.0.0.0 255.0.0.0 10.200.159.1 1 track 1
route outside 10.0.0.0 255.0.0.0 10.200.159.2 254
sla monitor 123
 type echo protocol ipIcmpEcho 10.2.3.4 interface outside
 num-packets 3
 frequency 10
sla monitor schedule 123 life forever start-time now
track 1 rtr 123 reachability
Thanks in advance,
Jason
mirober2
Hi Jason,
The config looks correct, and yes SLA monitoring will work when the tracked and backup route are on the same interface.
What does the output of 'show sla monitor operational-state' say?
-Mike
