ASA static NAT problem
shahid_duet
Level 3
Level 3
Dear boss
I m using ASA5510 for DMZ. Please see my attached diagram and configuration.
interface Ethernet0/0
nameif local
security-level 100
ip address 192.168.0.243 255.255.255.0
interface Ethernet0/1
nameif outside
security-level 0
ip address 10.0.0.2 255.255.255.252
interface Ethernet0/2
nameif DMZ
security-level 50
ip address 172.29.1.1 255.255.255.0
access-list DMZTOLocal extended permit ip host 192.168.0.241 192.168.0.0 255.255.0.0
static (DMZ,local) 192.168.0.241 172.29.1.5 netmask 255.255.255.255
access-group DMZTOLocal out interface local
policy-map global_policy
class inspection_default
  inspect dns preset_dns_map
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
My out side NAT is ok. I get local  to DMZ  ie 192.168.0.0/16 to 192.168.0.241(172.29.1.5),  but not getting 172.29.1.5 to 192.168.0.0/16.
What can i do if i want to get DMZ to Local ???
Please suggest me.
Thanking You
shahid
llamaw0rksE
Level 3
Level 3
I have some issues with your design.
Firstly I am not used to a inside interface ( a lan), with IP address ending in   .243, I am used to .1
My knowledge is limited so it might be perfectly legitimate.
Secondly with a basic license at least on the ASA5505, the DMZ could only be used for DMZ or internet bound traffic.
The internal lan could reach the DMZ or the internet.
Make sure your license permits a fully functioning DMZ.
Thirdly, I really dont care about your config at this point.  I would like to know in words, what your requirements are first.  Then we can look at implementation.  What is it that you need in your work environement in concepts.
Dennis Mink
your:
will still not allow access from DMZ--->Local
access-list DMZTOLocal extended permit ip host 172.29.1.5 192.168.0.0 255.255.0.0
and apply this to your  DMZ interface in  access-group DMZTOLOCAL in interface DMZ
also, fire up your packet tracer in ASDM and see what drops your traffic,
Dennis
Please remember to rate useful posts, by clicking on the stars below.
