ASA syslog problem
jgary
Community Member
My customer have a ASA 5550 in HA. It is the Internet Firewall.
In this moment the firewall have 50.000 connection. Customer review the log in the syslog server and noted wich not all syslog messages the firewall are notify to the syslog server.
The configuration is the follow:
logging enable
logging timestamp
logging standby
logging buffered debugging
logging trap debugging
logging asdm debugging
logging mail warnings
logging from-address [email protected]
logging recipient-address [email protected] level errors
logging facility 22
logging host management 192.168.120.222.
All rules have the log keyword and debugging level.
I think, the firewall can't send the all messages because is busy with the conection. Someone have been this problem.
Thank you
rajbhatt
Level 5
Level 5
For troubleshooting these few messages should be sufficient :for syslog U can remove buffered and trap debugging .
mail notifications stays as it is
logging host inside 1.2.3.4
logging timestamp
logging trap 5
logging on
Raj
jgary
Community Member
Thank you for you comment. But the proble is the login messages not reflect all activities and conections through the firewall.
Regards.
pager lines 24
logging enable
logging standby
logging buffer-size 1000000
logging monitor debugging
logging asdm errors
logging host inside 172.16.5.110
logging host inside 172.16.0.152 format emblem
logging class config asdm emergencies
logging class ids asdm debugging
no logging message 106015
no logging message 106006
no logging message 106001
no logging message 106023
no logging message 305012
no logging message 305011
no logging message 710005
no logging message 106100
no logging message 100000
no logging message 302014
no logging message 304002
no logging message 304001
no logging message 609002
no logging message 609001
no logging message 302016
no logging message 302021
no logging message 302020
logging message 106023 level informational
logging message 305012 level debugging
logging message 302015 level debugging
logging message 302014 level debugging
logging message 302013 level debugging
logging message 304001 level informational
logging message 302016 level debugging
jgary
Community Member
Thank you for you answer, i help me.
