ASA5505-50-BUN-K9 3DES license problem [Resolved]
I have ASA505 with 3DES disabled, i heard that i can have the 3DES license without fee, so i contacted cisco more than 10 times to have the license, and every time they send me the same licence as my parmanent base key: 5321ec6e 102e534b fc21e96c 841c8ca8 ce1727aa
I don't understand the problem, here is the show activation key output:
Running Permanent Activation Key:
0x5321ec6e 0x102e534b 0xfc21e96c 0x841c8ca8 0xce1727aa
Licensed features for this platform:
Maximum Physical Interfaces    : 8              perpetual
VLANs                          : 3              DMZ Restricted
Dual ISPs                      : Disabled       perpetual
VLAN Trunk Ports               : 0              perpetual
Inside Hosts                   : 50             perpetual
Failover                       : Disabled       perpetual
VPN-DES                        : Enabled        perpetual
VPN-3DES-AES                   : Disabled       perpetual
SSL VPN Peers                  : 2              perpetual
Total VPN Peers                : 10             perpetual
Shared License                 : Disabled       perpetual
AnyConnect for Mobile          : Disabled       perpetual
AnyConnect for Cisco VPN Phone : Disabled       perpetual
AnyConnect Essentials          : Disabled       perpetual
Advanced Endpoint Assessment   : Disabled       perpetual
Botnet Traffic Filter          : Disabled       perpetual
Intercompany Media Engine      : Disabled       perpetual
This platform has a Base license.
The flash permanent activation key is the SAME as the running permanent key.
And the license key that cisco send me every time isexactely the same but it should activate the 3DES encryption algorithm:
Inside Hosts                    : 50
Failover                        : Disabled
Encryption-DES                  : Enabled
Encryption-3DES-AES             : Enabled
Security Contexts               : Default
GTP/GPRS                        : Disabled
AnyConnect Premium Peers        : Default
Other VPN Peers                 : Default
UC Phone Proxy Sessions         : Default
Total UC Proxy Sessions         : Default
Platform = asa
JMX152040DW:      5321ec6e 102e534b fc21e96c 841c8ca8 ce1727aa
Can someone tell me where is the problem please?
Thank you in advance.
19 Replies 19
Result of the command: "show tech-support"
Cisco Adaptive Security Appliance Software Version 8.3(2)
Device Manager Version 6.3(2)
Compiled on Fri 30-Jul-10 20:17 by builders
System image file is "disk0:/asa832-npe-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 11 days 12 hours
Hardware:   ASA5505, 512 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash M50FW016 @ 0xfff00000, 2048KB
It has all requirements.
I'm trying to find how to update my firewall using ASDM GUI...
Yes, your memory is good.
To update via the GUI, Choose "Tools, Upgrade Software from Local Computer". In the dialog box that pops up pick "Image to upload" as ASA (not the default APCF) and then browse to your local copy of the new software. It will then upload the file using https to your ASA disk0, ask you if you want to make this the new boot image (choose yes) and then ask if you want to reload and upgrade now.
Remember the updated ASDM (asdm-711.bin) will give you the most functionality with the new release. You should follow the similar process to get it on the ASA, choosing instead ASDM from the "Image to Upload" drop down menu. You won't have to reload the ASA itself after you do that, only the ASDM client.
I update the ASA with asa911-k8.bin correctly.
But after i reloaded to install the new ASDM, i got message showig that the ASA 9.1 is not supported by ASDM 6.
After i could not connect to firewall using ASDM, i tryed the ssh:
I uploaded the asdm file asdm-711-52.bin, and when i try to make it default, i got an error:
ciscoasa# asdm image disk0:/asdm-711-52.bin
ERROR: % Invalid input detected at '^' marker.
The command is wrong ?
I proceeded using this article:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008067e9f9.shtml#maintask2
Here is some output:
Writing file disk0:/asdm-711-52.bin...
17790720 bytes copied in 37.990 secs (480830 bytes/sec)
ciscoasa# show disk0:
--#--  --length--  -----date/time------  path
  154  15962112    May 13 2011 14:12:22  asa832-npe-k8.bin
  155  2048        Apr 02 2012 20:21:40  syslog
  191  0           Apr 02 2012 20:21:40  syslog/LOG-2012-04-02-202141.TXT
  156  2048        Jan 01 1980 01:00:00  FSCK0000.REC
   20  2048        May 13 2011 14:13:36  coredumpinfo
   21  59          Dec 20 2012 23:25:36  coredumpinfo/coredump.cfg
  157  14457072    May 13 2011 14:14:22  asdm-632.bin
   10  2048        May 13 2011 14:15:34  log
   19  2048        Aug 06 2012 15:43:38  crypto_archive
  193  410212      Aug 06 2012 15:43:38  crypto_archive/crypto_arch_1.bin
  158  27260928    Dec 20 2012 23:18:18  asa911-k8.bin
  159  4096        Jan 01 1980 01:00:00  FSCK0001.REC
  161  4096        Jan 01 1980 01:00:00  FSCK0002.REC
  162  12998641    May 13 2011 14:19:40  csd_3.5.2008-k9.pkg
  163  2048        May 13 2011 14:19:42  sdesktop
  195  1462        May 13 2011 14:19:42  sdesktop/data.xml
  164  6487517     May 13 2011 14:19:44  anyconnect-macosx-i386-2.5.2014-k9.pkg
  165  6689498     May 13 2011 14:19:46  anyconnect-linux-2.5.2014-k9.pkg
  166  4678691     May 13 2011 14:19:48  anyconnect-win-2.5.2014-k9.pkg
  167  4096        Jan 01 1980 01:00:00  FSCK0003.REC
  168  4096        Jan 01 1980 01:00:00  FSCK0004.REC
  169  6144        Jan 01 1980 01:00:00  FSCK0005.REC
  170  6144        Jan 01 1980 01:00:00  FSCK0006.REC
  171  6144        Jan 01 1980 01:00:00  FSCK0007.REC
  172  22528       Jan 01 1980 01:00:00  FSCK0008.REC
  173  38912       Jan 01 1980 01:00:00  FSCK0009.REC
  174  34816       Jan 01 1980 01:00:00  FSCK0010.REC
  175  43008       Jan 01 1980 01:00:00  FSCK0011.REC
  176  2048        Jan 01 1980 01:00:00  FSCK0012.REC
  177  26624       Jan 01 1980 01:00:00  FSCK0013.REC
  178  2048        Jan 01 1980 01:00:00  FSCK0014.REC
  179  26624       Jan 01 1980 01:00:00  FSCK0015.REC
  180  2048        Jan 01 1980 01:00:00  FSCK0016.REC
  181  26624       Jan 01 1980 01:00:00  FSCK0017.REC
  182  2048        Jan 01 1980 01:00:00  FSCK0018.REC
  183  26624       Jan 01 1980 01:00:00  FSCK0019.REC
  184  2048        Jan 01 1980 01:00:00  FSCK0020.REC
  120  6791        Dec 21 2012 19:30:48  8_3_2_0_startup_cfg.sav
  185  568         Dec 20 2012 23:25:36  upgrade_startup_errors_201212202225.log
  186  568         Dec 21 2012 17:39:28  upgrade_startup_errors_201212211639.log
  189  568         Dec 21 2012 19:30:56  upgrade_startup_errors_201212211830.log
  190  17790720    Dec 21 2012 20:19:06  asdm-711-52.bin
128704512 bytes total (21164032 bytes free)
ciscoasa# asdm ?
  disconnect  Specify ASDM session id to be disconnected after this keyword
Can you help me please ?
PS: resolved by entring the command:  conf t
Yeeeesssssss!
The problem is solved!
Upgraded ASA version from 6.3(2)  to 7.1(1) 52
Upgraded ASDM version from 8.3(2) to 9.1(1)
And result: the 3DES enabled like a charm:
Result of the command: "show version"
Cisco Adaptive Security Appliance Software Version 9.1(1)
Device Manager Version 7.1(1)52
Compiled on Wed 28-Nov-12 10:38 by builders
System image file is "disk0:/asa911-k8.bin"
ciscoasa up 11 mins 51 secs
Hardware:   ASA5505, 512 MB RAM, CPU Geode 500 MHz,
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode        : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode     : CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode       : CNlite-MC-IPSECm-MAIN-2.08
                             Number of accelerators: 1
0: Int: Internal-Data0/0    : address is e8b7.4836.9f54, irq 11
1: Ext: Ethernet0/0         : address is e8b7.4836.9f4c, irq 255
2: Ext: Ethernet0/1         : address is e8b7.4836.9f4d, irq 255
3: Ext: Ethernet0/2         : address is e8b7.4836.9f4e, irq 255
4: Ext: Ethernet0/3         : address is e8b7.4836.9f4f, irq 255
5: Ext: Ethernet0/4         : address is e8b7.4836.9f50, irq 255
6: Ext: Ethernet0/5         : address is e8b7.4836.9f51, irq 255
7: Ext: Ethernet0/6         : address is e8b7.4836.9f52, irq 255
8: Ext: Ethernet0/7         : address is e8b7.4836.9f53, irq 255
9: Int: Internal-Data0/1    : address is 0000.0003.0002, irq 255
10: Int: Not used            : irq 255
11: Int: Not used            : irq 255
Encryption-DES                    : Enabled        perpetual
Encryption-3DES-AES               : Enabled        perpetual
AnyConnect Premium Peers          : 2              perpetual
Other VPN Peers                   : 10             perpetual
Total VPN Peers                   : 12             perpetual
UC Phone Proxy Sessions           : 2              perpetual
Total UC Proxy Sessions           : 2              perpetual
Cluster                           : Disabled       perpetual
Serial Number: JMX152040DW
Running Permanent Activation Key: 0x5321ec6e 0x102e534b 0xfc21e96c 0x841c8ca8 0xce1727aa
Configuration register is 0x1
Configuration last modified by enable_15 at 20:56:49.179 CET Fri Dec 21 2012
Last thing please, do i have to delete the old asa and asdm files from firewall ? (asa832-npe-k8.bin and
asdm-632.bin)
Thank you so much Mr Marvin Rhoads
You're welcome Houari. I'm glad it worked out well for you.
Yes you can delete the old ASA and ASDM binary images if eerything is working OK on the new images.
You can also delete all of those fsck____.rec files (file system check records - usually due to the box reloading after software having crashed or  being shut down by hard power off).
The "upgrade_startup_errors: fiules can also be deleted once you've reviewed them for any issues reported during the upgrade process. (You can look at those plain text files from CLI with the command "more" followed by the filename.)
Thanks for the ratings.
