ASA5505 - PPPOE on Outside Interface
James Davies
Would like some advice please, I have set up a 5505 for a home worker,. who will be using VPN to connect to various offices. On the Outside interface I have set up a PPPOE connection profile as below:
vpdn group Plusnet request dialout pppoe
vpdn group Plusnet localname XXXXXXXX
vpdn group Plusnet ppp authentication chap
vpdn username XXXXXXXt password XXXXXX store-local
dhcpd auto_config outside
dhcpd address 192.168.11.5-192.168.11.254 inside
dhcpd enable inside
On the outside interface I have:
interface Vlan2
 description Outside Connection to Plusnet
 nameif outside
 security-level 0
 pppoe client vpdn group Plusnet
 ip address pppoe setroute
It just will not connect and get an IP Address. Plusnet have provided a static IP to the home.
I tried an older cisco router and this worked absolutely fine. Username and passwords are absolutely fine. I did username and password and CHAP and off it went..
Am I missing something on the ASA?
James Davies
This is now resolved. seems to have duplicated the PPPOE config when I looked on the cli, removed and it is all good.
