ASA5510 permit incoming connection from remote lan
dufour001
I actually have a config like this :
Main Site  -- cisco 3750 -- ISP SDSL router -- ISP MPLS -- ISP SDLS router -- cisco 2821 -- Remote Site
                                                               ISP firewall (only for port forwarding)
        internet
Actually all service from site to site is permitted, without restriction.
I want to insert an ASA to block some internet traffic on main site :
Main Site  -- cisco 3750 -- ASA5510 --  ISP SDSL router -- ISP MPLS -- ISP SDLS router -- cisco 2821 -- Remote Site
        internet
I try to configure my ASA5510.
No problem for outgoing connection or to permit a single service on main site.
But impossible to give access to all service/connection from all remote site to main site.
Main Site is 192.168.96/21
Remote site is 192.168.144.1/21
Here my config
ASA Version 8.4(2)
interface Ethernet0/1
nameif OUTSIDE
security-level 100
ip address 192.168.96.2 255.255.255.248
interface Ethernet0/2
nameif INSIDE
security-level 100
ip address 192.168.96.17 255.255.255.248
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list OUTSIDE_access_in extended permit ip any any
access-list INSIDE_access_out extended permit ip any any
access-list OUTSIDE_access_out extended permit ip any any
access-list INSIDE_access_in extended permit ip any any
object network obj_any
nat (INSIDE,OUTSIDE) dynamic interface
access-group OUTSIDE_access_in in interface OUTSIDE
access-group OUTSIDE_access_out out interface OUTSIDE
access-group INSIDE_access_in in interface INSIDE
access-group INSIDE_access_out out interface INSIDE
route OUTSIDE 0.0.0.0 0.0.0.0 192.168.96.1 1
route INSIDE 192.168.99.0 255.255.255.0 192.168.96.18 1
route INSIDE 192.168.100.0 255.255.255.0 192.168.96.18 1
route INSIDE 192.168.101.0 255.255.255.0 192.168.96.18 1
route INSIDE 192.168.102.0 255.255.255.0 192.168.96.18 1
route INSIDE 192.168.103.0 255.255.255.0 192.168.96.18 1
Thx
7 Replies 7
varrao
Level 10
Level 10
What do you see in the captures and logs on the ASA. Can you also explain in a bit more detail what the exact issue is?
You said one single service is permitted but not all, can you provide what services are working and what not??
Varun
Varun Rao
I can permit one single service with "normal" port forwarding.
But I want that all my remote lan can access all my main site for all services (file sharing, mail, TSE, ...).
Actually all connection from remote site to main site are blocked.
Tried som debug output but, without collect any interesting datas.
You would need a nat statement to allow the connections, I can see only one, which is for internal users to access internet. Cna you give me an example of any one machine on the main site that needs to be accesses from remote site?
Varun
Varun Rao
We have severals machines (File sharing, AD, TSE, lot of other services) that can be accessed from remote sites
for example 192.168.100.100 is a TSE on main site.
So I'm looking for a config to allow all incoming connections from remote site.
In place of allowing per IP/service.
Is it possible ?
Then you might need the following config:
object network remote_site
  subnet 10.0.0.0 255.0.0.0
object network main_site
  subnet 192.168.0.0 255.255.255.0
nat (outside,inside) source static remote_site remote_site destination static main_site main_site
This shoudl work for us, I have just assumed the subnets for your remote and main site, you can change them accordingly.
Hope this helps,
Varun
Varun Rao
I tried that but don't work.
With that, I can't access remote site from main site ...
I tried the same but in unidirectionnal mode.
So I can acces the remote site , but impossible to have connection from remote site to main site.
thx
Anyone has idea ?
Thx
