ASA5515X-IPS management 0/0 to LAN
rdsalmans
I've recently setup two ASA5515X in A/S each with IDS. When I had them in the lab I was able to access the IPS's via IME but now that it's at the datacenter it's not working (of course). I've got the IPS configured with an IP on our LAN and the ASA's Management0/0 interface configured as:
interface Management0/0
no nameif
security-level 100
no ip address
management-only
The Management0/0 interface is plugged into a switchport on our LAN VLAN. From the ASA it's seeing the IPS as Up and I've verified the IPS network settings. Any ideas? Did I forget something? TIA!
15 Replies 15
It's fixed. It was a problem with the Management interface plugged into the wrong switchport. Verified by shutting down the switchport and checking the Management 0/0 interface and found that when the switchport was shutdown, the Management0/0 port did not show down/down. Finally figured out where the person had plugged the cable in and moved the VLAN's around and it's up now. Thanks for your assistance.
