06-28-2013 07:14 PM - edited 03-11-2019 07:04 PM
We have site-2-site VPN between two the same ASAs and I'm connecting to the some switch beside of one ASA through internet.
We had default configuration for inspection:
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect skinny
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect icmp
inspect ipsec-pass-thru
and after some times we have lost connection in the middle of ssh session or telnet or Radmin and others (like oracle sql)...
Debug show this messages:
Jun 29 2013 07:52:56: %ASA-6-302304: Teardown TCP state-bypass connection 356159 from outside:192.168.A.A/60669 to DB-PROD:10.B.B.B/1521 duration 0:00:23 bytes 2633284 Flow closed by inspection
Jun 29 2013 07:54:33: %ASA-6-302014: Teardown TCP connection 355841 for outside:10.X.X.X/59883 to management:10.Y.Y.Y/22 duration 0:02:48 bytes 176730 Flow closed by inspection
Jun 29 2013 07:54:38: %ASA-6-302014: Teardown TCP connection 356316 for outside:10.X.X.X/59902 to management:10.Y.Y.Y/23 duration 0:01:50 bytes 11250 Flow closed by inspection
This happened when i start ping A.A.A.A repeat 100000
and after many !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! we have a stop ssh or telnet sesssion.
If we set
set connection advanced-options tcp-state-bypass
everything working fine.
What can we do with this inspection?
thx,
Alex.
07-02-2013 12:08 AM
I think it's not the same bug, because in my situation, tcp connection really closes incorrectly.
WBR,
Alex.
07-02-2013 09:57 AM
Yeah, I would like to see the traffic pattern of that connection,
I hope the issue does not happen again but just in case can you take a capture on both interfaces of the ASA to see what's the FW seeing that could be causing the problem?
Remember to rate all of the helpful posts.
For this community that's as important as a thanks.
