ASAv50 Display failover state difference CLI with ASDM
jewfcb001
Level 7
Level 7
We deploy ASAv50 version 9.12 but I found  ASAv50 display failover state difference CLI with ASDM.
CLI Display : Active/Active
ASDM        : Active/Standby
Please suggest me .
9 Replies 9
Pulkit Saxena
Can you share the "show version" from ASA ?
Pulkit
Hi Pulkit
ASAv Version 9.12(3)9
Cristian Matei
    Can you post the following output from both ASA's? "show version", "show failover", "show failover state".
Cristian Matei.
Sheraz.Salim
what is the ASDM version you on.
make sure you on ASDM version 7.13.1
please do not forget to rate.
I don't think that ASAv should be running in active/active mode. What are you running the ASAv on? VMware, KVM, Azure?
agree ASAv does not support active/active.
Hi Sheraz
ASDM Version : 7.12(2)14
I not install new asdm I use default asdm in default image on ASAv .
I don't think this is an ASDM issue as it is showing correct output, now from CLI perspective.
If you are seeing "active/active" in "show version" output, you can ignore that, it is brought from the ASA code.
However if you are seeing "active/active" in "show failover" output, let us know and share the complete "show failover" output.
Pulkit
@Pulkit Saxena I agree its not the ASDM issue. I was curious to know what version is on. in regards to ASA cli showing Active/Active could be a cosmetic bug. unless show failover show the same thing even though active/active (multi-context) is not supported in virtual appliance of asav.
