ASDM_HANDLER problem on multiple context mode
Rodrigo Gurriti
Level 6
Level 6
Has any anybody seen this error?
On the firewall multiple context I used to jump from one context to another, but now when I log in to the admin context and I try to jump to another context I receive this error. Could no find any bug on release notes for that.
asdm error
Jouni Forss
I have not personally seen this error before. Though I don't use ASDM that much anyway. We used to have FWSMs in multiple context mode and now have ASAs running multiple context mode and I have never seen this.
Have you checked the situation (as the error message suggests) from the CLI of the ASA to see if there is a lot of ASDM sessions in the "admin" context of the unit?
show asdm sessions
- Jouni
I've checked the asdm sessions on all the contexts and there were only one open on the admin.
The odd part of this issue is that I can log in via ASDM on each context separately but not from the ADMIN context.
My guess will be on the java, but since I don't have direct access to this box I will have to wait for a maintenance window.
nkarthikeyan
Level 11
Level 11
Hi Rodrigo,
What is your ASDM version and Java Version? Also please check for the memory issues with the device.
Karthik
