ASDM Problems
caioamonteiro
Level 2
Level 2
Hi everone,
I recently bought an all brand new ASA 5510 and it is here by my side. I'm trying to configure it but when entering https://192.168.1.1/admin I get Page Not Found error on IE. I'm able to ping 192.168.1.1 and have success telnet 443 port.
Any idea?
Regards.
2 Accepted Solutions
Hi Caio,
Apart from checking the Java version, you do necessarily need to add these on the ASA:
ssl encryption rc4-sha1 aes128-sha1 aes256-sha1 3des-sha1
and
crypto key rsa generate modulus 1024
It should work after this.
Varun Rao
Security Team,
Cisco TAC
Varun Rao
Hello Caio,
Please add the following command, this should do it
ssl encryption aes256-sha1 aes128-sha1 3des-sha1
Rate all the helpful post
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
13 Replies 13
varrao
Level 11
Level 11
Hi Caio,
Can you please share an output of:
show run asdm
show run http
show crypto key mypubkey rsa
show run all ssl
You can also follow this doc for troubleshooting:
https://supportforums.cisco.com/docs/DOC-15016
Hope this helps.
Varun Rao
Security Team,
Cisco TAC
Varun Rao
Hi Varun,
sh run http:
http server enable
http 192.168.1.0 255.255.255.0 management
sh run all ssl:
ssl server-version any
ssl client-version any
ssl encryption des-sha1
The other two return nothing.
Thanks!
Marvin Rhoads
I assume you are plugged directly into the Mgmt Ethernet port and getting a DHCP address from the ASA (or have manually assigned yourself one in the 192.168.1.0/24 network).
Can you check the output (from console) of "show activation-key"? Look for the 3DES/AES license to be active.
I have seen issue with updated browsers not working with ASDM due to the encryption expected by the browser's security settings not being active on the ASA. It is a free upgrade - go to www.cisco.com/go/licensing to get an activation key for 3DES/AES.
Hi Marvin
VPN-3DES-AES                   : Disabled
Is this one?
Thanks!
Hi Caio,
Yes, as correctly mentioned by Marvin, you would need a 3DES license for it, but its not an issue, you can generate free license from  this site:
https://tools.cisco.com/SWIFT/LicensingUI/loadDemoLicensee?FormId=139
Hope that helps.
Varun Rao
Security Team,
Cisco TAC
Varun Rao
Thanks for helping. I added the license but the problem keeps happening.
Then  can you please share teh outputs I requested
Varun Rao
Security Team,
Cisco TAC
Varun Rao
Sorry, I replied this on your post. Here goes again:
Hi Varun,
sh run http:
http server enable
sh run all ssl:
Thanks!
Hi Bro
Do you have the latest java version from www.java.com installed on your workstation that's directly connected to the Management 0/0 interface? Furthermore, please do remove the proxy settings in your Internet Browser. Is this issue happening to all workstations when trying to access the ASDM or only your workstation?
Warm regards,
Ramraj Sivagnanam Sivajanam
Going to try other CPU and updating my Java.
Thanks for the tip!
Hi Caio,
and
Varun Rao
Security Team,
Cisco TAC
Varun Rao
Hello Caio,
Julio
Julio Carvajal
caioamonteiro
Level 2
Level 2
Thanks Varun and jcarvaja!
Both answers correct.
