ASDM will not run after ASA upgrade to 9.6(3)1
trector
Running macOS Sierra version 10.12.4
Java Version is 8 Update 131
ASA5512 running 9.6(3)1
ASDM running 7.1(1)151
ASDM will not run as Java Webstart or ASDM Launcher
Get "javax.net.ssl.SSLHandshakeException: Received fatal alert: handshake_failure" under wrapped exception
Get ""com.sun.deploy.net.FailedDownloadException: Unable to load resource: https://xxx.xx.xx.xx:8443/admin/public/asdm.jnlp" under exception
Have an open TAC case with no resolution
Works fine under Windows but not under MAC
Downgrading the ASDM makes no difference.
Backing down the ASA code version allows the ASDM to work.
Here is the full Java message:
at com.sun.deploy.net.DownloadEngine.actionDownload(Unknown Source)
at com.sun.deploy.net.DownloadEngine.downloadResource(Unknown Source)
at com.sun.deploy.cache.ResourceProviderImpl.getResource(Unknown Source)
at com.sun.javaws.Launcher.updateFinalLaunchDesc(Unknown Source)
at com.sun.javaws.Launcher.prepareToLaunch(Unknown Source)
at com.sun.javaws.Launcher.launch(Unknown Source)
at com.sun.javaws.Main.launchApp(Unknown Source)
at com.sun.javaws.Main.continueInSecureThread(Unknown Source)
at com.sun.javaws.Main.access$000(Unknown Source)
at com.sun.javaws.Main$1.run(Unknown Source)
at java.lang.Thread.run(Thread.java:748)
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
at sun.security.ssl.Alerts.getSSLException(Alerts.java:154)
at sun.security.ssl.SSLSocketImpl.recvAlert(SSLSocketImpl.java:2023)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1125)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1375)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1403)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1387)
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1546)
at sun.net.www.protocol.http.HttpURLConnection.access$200(HttpURLConnection.java:91)
at sun.net.www.protocol.http.HttpURLConnection$9.run(HttpURLConnection.java:1466)
at sun.net.www.protocol.http.HttpURLConnection$9.run(HttpURLConnection.java:1464)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.AccessController.doPrivilegedWithCombiner(AccessController.java:782)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1463)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:254)
at com.sun.deploy.net.HttpUtils.followRedirects(Unknown Source)
at com.sun.deploy.net.BasicHttpRequest.doRequest(Unknown Source)
at com.sun.deploy.net.BasicHttpRequest.doGetRequest(Unknown Source)
TAC has not able to fix the problem.
Any Ideas?
15 Replies 15
Thanks for the quick response.
I did forget to mention that I have had to add ASDM hosts to the allowed Java list for some time now, and that the multiple firewalls that cannot be accessed properly are all in this list as both IP address and IP address/port.  I had to start adding these a year or 2 ago when that big Java change came out.
