Basic Setup Problem on Pix 515E
lobber123
Visitor
I'm hoping someone will be able to help me. We have just taken delivery of 2 Cisco Pix 515E firewalls and we are unable to access the PDM or get a DHCP address. We have plugged in the Firewall, connected it to a laptop with a crossover cable. I have assigned the laptop a default IP of 192.168.1.2 as stated in the manual and then opened IE to browse to http://192.168.1.1/startup.html as stated in the manual. We have Java installed as well. When we browse to the web page we get a page cannot be displayed. The laptop does not get an IP address either if we leave DHCP on instead of a static IP. The firewall cannot ping the laptop and vice versa from the console. If I ping the firewall from the laptop and do a show arp on the console, the firewall displays the arp details of the laptop.
These are both brand new firewalls, untouched yet we cannot get in to the PDM or configure them as stated in the Getting Started Guide.
Can anyone help? Is there some new command we need to run first I don't know about?
Andy
12 Replies 12
jmia
Level 11
Level 11
Andy,
Try: https//192.168.1.1/startup.html
HTTPS = HTTP over SSL
Jay
Andy,
Slight typo on my other post:
It should be - https://192.168.1.1/startup.html
Jay
It seems you are not the only one who makes a typo. I meant to type https not http. Thanks for replying, but we have tried that. Any other ideas?
I have enabled logging on the console and if I ping the firewall from the laptop plugged in to the inside port it logs a message saying the UDP packet from the laptop to the firewall is being discarded. Its all very strange as I thought the inside port didn't block anything by default?
Thanks in advance for any insight.
Cheers
Andy
Andy,
Have you got access to the pix via console port, if so, check the config to see if you have the following command:
http server enable
http
If all fails you can configure the firewall via CLI (Command Line Interface) from the console port. To be honest I prefer to use CLI then PDM (encounterd to many issues with PDM).
If you need help on this then let me know and also do you need dhcp on the pix?
Let me know,
Jay
Jay,
Thanks for trying to help. I've pasted a copy of the current config below from the write term command. This may make it easier to see what is currently configured on the Pix.
PIX Version 6.3(3)
interface ethernet0 auto shutdown
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password ******** encrypted
passwd ******** encrypted
hostname Test
domain-name test.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
pager lines 24
logging on
logging buffered debugging
mtu outside 1500
mtu inside 1500
no ip address outside
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address inside
pdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.1.2 255.255.255.255 inside
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
And the show ver command:
Cisco PIX Firewall Version 6.3(3)
Cisco PIX Device Manager Version 3.0(1)
Compiled on Wed 13-Aug-03 13:55 by morlee
Test up 9 mins 59 secs
Hardware: PIX-515E, 64 MB RAM, CPU Pentium II 433 MHz
Flash E28F128J3 @ 0x300, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Encryption hardware device : Crypto5823 (revision 0x1)
0: ethernet0: address is 000f.8f20.64f9, irq 10
1: ethernet1: address is 000f.8f20.64fa, irq 11
Licensed Features:
Failover: Enabled
VPN-DES: Enabled
VPN-3DES-AES: Enabled
Maximum Physical Interfaces: 6
Maximum Interfaces: 10
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
While we don't require DHCP, I mentioned it because the getting started guide says use it. It seems the the inside port receives packets but it never allows packets out again.
Cheers
Andy
Andy,
From the config that you have posted, I don't see DHCP server enabled on the pix? Has this been removed? This is why the pix is not issuing your laptop the default IP address!!
Where is the cable from Ethernet 1 plugged into? a switch/hub? I have just looked at the startup guide for the 515E, step1.
If the DHCP Server command has been removed then you'll need to configure the pix via CLI. But if you are saying that the pix config has not been tempered with then I'm really surprised that the DHCP server is not configured on the pix!!!
Let me know,
Jay
We haven't changed the config at all. This is as new out of the box hence why I am as confused as yourself. We assigned the laptop a static IP address but still no joy. The cable from Ethernet1 is currently a crossover cable and is plugged directly in to the laptop. We have also tried using a standalone hub with only the PIX and the laptop connected. We have tried 2 other laptops and a desktop just in case.
We can access the PIX via the CLI no problem using the console, we just cannot get any IP connection whatsoever.
We have 2 Pix firewalls, both brand new and they both exhibit the same problem. This is actually our 2nd set of boxes as our supplier RMA'd the first two (with exactly this problem strangely enough) as they could not get it to work either. What are the chances of 4 boxes being faulty? Thats why I am now seeking help here as there must some change to the default config that is not mentioned in the documentation that comes with the Pix.
If I do a SHOW DHCPD at the console in CLI, nothing is displayed so I agree that it is not enabled. Very confusing as it is supposed to be. I could set it up, but like I mentioned, I won't want to use it anyway and would only disable it again.
I'm reluctant to start configuring the PIX with all the rules etc that we need using the CLI until I can understand what is wrong here. Why can I not ping the PIX from the laptop or the laptop from the PIX?
Cheers
Andy
Andy,
I am SHOCKED, that this is the 2nd sets of pix's and you are running into the same problem. I have read the documentation on the 515E and it states that you CAN configure the 515 via the start-up guide as you are doing. The only thing that comes to mind is, maybe your supplier has a bad batch of pixes! One idea could be, is to get your supplier to contact Cisco and ask them why you are encountering this problem or if you have a SmartNet contarct with Cisco you can open a TAC case for the pixes.
Apart from this I'm lost for an explanation on your problem, I've not found any bug reports on this problem either.
Sorry Andy, 😞
Best to ask Cisco TAC on this problem.
Hope it all works out.
Jay
Andy, are you using windows XP? If yes then turn off the inbuilt firewall and make sure you have the Java component installed. Windows XP does not come prebundled with Java. You can download it from java.com or just install netscape 7 as it comes prebundled with Java.
I hope this helps.
caaustin9
Community Member
Good morning. I had the same problem initially with the 515 PDM. I was able to access the PDM by following the 'Restore the Default Configuration' steps located on page 25 of the Quick Start Guide. Step 2 uses the word 'configuration', but you should use 'configure' instead. After I completed the steps, I could access the PDM. I skipped the dhcp stuff. Hope this helps.
lobber123
Visitor
I'm just posting to say the problem has been resolved. Our supplier had shipped us 2 secondary failover firewalls, instead of one primary and one secondary. It appears that the PDM and DHCP don't work on the secondary straight out the box, hence the issues we experienced. Shocking that the supplier sent us 6 secondarys before we managed to make them understand.
Thanks for all your help and suggestions. This is a great community and I'm sure I will be posting again as I try to get them configured.
Cheers
Andy
Andy,
Glad to hear that you got this resolved. Suppliers.. eh.. who needs them! The PDM and DHCP is not supplied with secoundary units out of the box as you know now.
Well let us know if you need help with the config etc.
Jay
