03-21-2021 02:24 PM
03-21-2021 03:49 PM
What version are you running? Certainly on version 6.7 it's under the routing section.
You'll probably have to configure it using flexconfig.
03-22-2021 09:11 AM
In the current recommended release (6.6.1), note that BGP is configurable via the FDM GUI:
OSPF and BGP configuration moved to the Routing pages. |
In previous releases, you configured OSPF and BGP in the Advanced Configuration pages using Smart CLI. Although you still configure these routing processes using Smart CLI, the objects are now available directly on the Routing pages. This makes it easier for you to configure processes per virtual router. The OSPF and BGP Smart CLI objects are no longer available on the Advanced Configuration page. If you configured these objects before upgrading to 6.6, you can find them on the Routing page after upgrade. |
Previous releases required either Flexconfig (pre-6.5) or smart CLI (release 6.5 only) to configure BGP on a locally-managed FTD device.
03-21-2021 02:28 PM
Yes BGP is supported on FDM.
03-21-2021 03:45 PM
Thank you, @Rob Ingram.
But How do I access that part? I mean when I go in the Device part then in Routing, I only see Static Routing.
03-21-2021 03:49 PM
03-21-2021 04:04 PM
FTD and FDM version is the same, right?
03-21-2021 04:07 PM
Yes. FDM just means you are using local management of the FTD software.
03-21-2021 04:09 PM
03-22-2021 09:11 AM
03-23-2021 05:12 PM
Hi @Rob Ingram and @Marvin Rhoads, thanks for your support.
