Bookmark
Subscribe
2464
BGP configuration on FPR 4110 using FDM
Serge D
Is it possible to configure bgp on cisco fpr 4110 using fdm?
2 Accepted Solutions
What version are you running? Certainly on version 6.7 it's under the routing section.
You'll probably have to configure it using flexconfig.
In the current recommended release (6.6.1), note that BGP is configurable via the FDM GUI:
OSPF and BGP configuration moved to the Routing pages.
In previous releases, you configured OSPF and BGP in the Advanced Configuration pages using Smart CLI. Although you still configure these routing processes using Smart CLI, the objects are now available directly on the Routing pages. This makes it easier for you to configure processes per virtual router.
The OSPF and BGP Smart CLI objects are no longer available on the Advanced Configuration page. If you configured these objects before upgrading to 6.6, you can find them on the Routing page after upgrade.
Previous releases required either Flexconfig (pre-6.5) or smart CLI (release 6.5 only) to configure BGP on a locally-managed FTD device.
8 Replies 8
@Serge D
Yes BGP is supported on FDM.
Serge D
Thank you, @Rob Ingram
But How do I access that part? I mean when I go in the Device part then in Routing, I only see Static Routing.
FTD and FDM version is the same, right?
Yes. FDM just means you are using local management of the FTD software.
Ok thank you, so I'm running version 6.3
Hi @Rob Ingram and @Marvin Rhoads, thanks for your support.
