BGP for load balancing and failover
ymadheka
Level 4
Level 4
Hi Team,
On of our customer wants to implement two links of 10mb each and run BGP for load balancing and failover between two links, is it be supported in 5506 / 5516?
Found the below references for failover but not for load balancing:
ASA Border Gateway Protocol Configuration Example: http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/118050-config-bgp-00.html
Load Sharing with BGP in Single and Multihomed Environments:http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13762-40.html
Thanks in advance for any help.
Thanks & Regards,
Yogesh Madhekar
0 Replies 0
