Cable-Based Active/Active Failover or LAN-Based Active/Active Failover
r.docuyanan
Level 3
Level 3
Anyone can help what are the Pros and Cons of Cable Based Active/Active Failover over LAN-Based?
Also, why there is a need for switch in the LAN Based Failover? Isnt it a point of failure as well? Why can't a cross cable be used?
Lastly, How fast is the TCP-session handover to the other Active Pair when the other box fails, something like a Cisco Load Balancer kind of mechanism?
Or if fast stateful failover is needed, does the Cisco Load Balancer CSS11501 for PIX7.2(Active Active) come into play?
