Can I assign more than 1 vlan to a sub-interface when running an ASA transparently using contexts?
rzc0v0-chris
I have a client who want to run an ASA5550 transparently using contexts in multiple mode as below.
Context 1: Service
Incoming trunk containing 81 and 82
Output trunk containing 86 and 87
81 -> 86
82 -> 87
Context 2: Management
Incoming trunk containing 10,11,12,13,14,15
Output trunk containing 70,71,72,73,74.75
10 -> 70
11 -> 71
12 -> 72
13 -> 73
14 -> 74
15 -> 75
I was under the impression from what I have read that you could only have 2 vlans per context, 1 on each interface/sub-interface and therefore for this to work they would have to split it down into 14 contexts. Am I correct or can you add more vlans to each context interface? unfortunatly I do not have a lab I can use to test this scenario.
Any input greatly appreciated!
m.kafka
Level 4
Level 4
you can configure many VLANs in the system context and asign them to transparent firewall contexts via the "context" command, If the firewall contexts are transparent you can only assign a maximum of two for each transparent FW. Solution: upgrade the number of contexts via licensing.
In your case 8 simultaneous contexts:
81 -> 86 - ctx 1
82 -> 87 - ctx 2
10 -> 70 - ctx 3
11 -> 71 - ctx 4
12 -> 72  -ctx 5
13 -> 73 - ctx 6
14 -> 74 - ctx 7
15 -> 75  -ctx 8
Rgds, MiKa
