Cannot configuring NAT using outside interface ip to Two different dmz servers
Rowlands Price
Level 5
Level 5
Hi Support,
I have a litte issue
I have a Cisco ASA 5525-x using version 8.6 (1)
My issue is that i cannot configure nat to allow users from Internet to access servers located on dmz1 and dmz4
The nat should use the outside ip interface.
outside ip: 172.16.1.1 (for testing)
dmz1; server ip: 192.168.46.15, ports must be used: https and 8080
Dmz4: server ip 192.168.35.2, port must be used: tcp 7909, 7910 and 7911
All servers from dmz must access internet.
Can you please help me regarding nat configuration?
Attached is my diagram
23 Replies 23
Ok now this is clear.
Remove the nat:
No nat (dmz-egov,outside) source dynamic dmz-egov_network interface
And replace by :
nat (dmz-egov,outside) after-auto source dynamic dmz-egov_network interface
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Hi Francesco,
It's working fine NOW
Many Thanks
That means, i will need to apply the same nat for all interfaces? (inside and dmz-etax)?
regards
For dynamic nat, it's better doing that way then you're sure it'll be the last statement will hit and no overlap with specific nats.
Francesco
Ok, but what about others interfaces to go to internet?
About theses nat ?
nat (inside,outside) source dynamic OBJ_GENERAL_ALL interface
nat (dmz-etax,outside) source dynamic dmz-etax_network interface
when i applied this, its not working again
Or i need inside nat to reach internet,
how to solve this please
Have you changed then with the after-auto keyword line the previous one?
Francesco
just changed the three nat with after-auto and it's working fine now
Thanks for your precious support
Best Regards
You're very welcome
Francesco
Rowlands Price
Level 5
Level 5
Hi Francesco
Many Thanks,
why this line please:
this is a nat from outside to inside, this must be denied by default, or what please
nat (outside,inside) source static any any destination static interface dmz4-srv service Obj-Ports Obj-Ports
