Cannot ping other interface (ASA 5506-x problem)
kelvin.lui11
I have a firewall problem.Why i can't ping outside gateway 192.168.1.90?
My pc ip address is 10.10.1.1. I have set the PAT and ACL.Here is my topology as below.Please help.Thank you!
Can you check if your Firewall is turned off on the PC ?
Also from the PC are you able to ping 10.10.1.1 ?
Please add a DNS server on your PC ( 4.2.2.2) and check if you can access Internet under the TCP/IPV4 settings.
Aditya
10 Replies 10
kelvin.lui11
Here is my configASA Version 9.5(2)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface GigabitEthernet1/1
 nameif outside
 security-level 0
 ip address 192.168.1.90 255.255.255.0
interface GigabitEthernet1/2
 nameif inside
 security-level 100
 ip address 10.10.1.1 255.255.255.0
interface GigabitEthernet1/3
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/4
 nameif inside2
 security-level 0
 ip address 3.3.3.4 255.255.255.0
interface GigabitEthernet1/5
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/6
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/7
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/8
 shutdown
 no nameif
 no security-level
 no ip address
interface Management1/1
 management-only
 no nameif
 no security-level
 no ip address
ftp mode passive
clock timezone HKST 8
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any
 subnet 10.10.1.0 255.255.255.0
object network abcd
object network qwert
 subnet 192.168.1.0 255.255.255.0
object network source
 range 10.10.1.2 10.10.1.100
object network aaaa
 range 192.168.1.91 192.168.1.254
object network jjjjj
 host 192.168.1.90
object network TestNet1
 subnet 3.3.3.0 255.255.255.0
object network bbbb
 range 192.168.1.1 192.168.1.89
object-group network d
 network-object object aaaa
object-group network abcde
 network-object object abcd
object-group network qwer
 network-object object qwert
object-group network sourceaddress
 network-object object source
 network-object 10.10.1.0 255.255.255.0
object-group service DM_INLINE_SERVICE_1
 service-object ip
 service-object icmp
 service-object icmp6
 service-object icmp echo
 service-object icmp echo-reply
 service-object tcp-udp destination eq www
object-group service DM_INLINE_SERVICE_2
 service-object ip
 service-object icmp
 service-object tcp-udp destination eq echo
 service-object tcp destination eq echo
 service-object tcp destination eq www
object-group service DM_INLINE_SERVICE_3
 service-object ip
 service-object icmp
object-group service DM_INLINE_SERVICE_4
 service-object ip
 service-object icmp
object-group service DM_INLINE_SERVICE_5
 service-object ip
 service-object icmp
object-group network DM_INLINE_NETWORK_1
 network-object object jjjjj
access-list global_access extended permit object-group DM_INLINE_SERVICE_1 any a        ny
access-list inside_access_in extended permit object-group DM_INLINE_SERVICE_2 an        y any
access-list outside_access_in extended permit object-group DM_INLINE_SERVICE_3 a        ny any
access-list allow_ping_outside extended permit object-group DM_INLINE_SERVICE_4        any interface outside
access-list allow_ping extended permit object-group DM_INLINE_SERVICE_5 any any
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu inside2 1500
no failover
no monitor-interface service-module
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
icmp permit any unreachable outside
icmp permit any echo outside
icmp permit any echo-reply outside
icmp permit any time-exceeded outside
icmp permit 192.168.1.0 255.255.255.0 outside
icmp permit 10.10.1.0 255.255.255.0 outside
icmp permit any inside
icmp permit 10.10.1.0 255.255.255.0 inside
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) after-auto source dynamic obj_any interface
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
access-group global_access global
route-map abc permit 1
 match ip address global_access
 match ip next-hop global_access
route outside 0.0.0.0 0.0.0.0 192.168.1.1 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
http 10.10.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
service sw-reset-button
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpoint _SmartCallHome_ServerCA
 no validation-usage
 crl configure
crypto ca trustpool policy
crypto ca certificate chain _SmartCallHome_ServerCA
telnet timeout 5
no ssh stricthostkeycheck
ssh 192.168.1.0 255.255.255.0 outside
ssh 10.10.1.0 255.255.255.0 inside
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
management-access inside
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
dynamic-access-policy-record DfltAccessPolicy
class-map global-class
 match default-inspection-traffic
class-map inside-class
class-map inspection_default
class-map outside-class
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
  inspect icmp error
policy-map outside-policy
 class outside-class
  inspect icmp
  inspect icmp error
policy-map global-policy
 class global-class
  inspect icmp
policy-map inside-policy
 class inside-class
  inspect icmp
  inspect icmp error
service-policy global_policy global
service-policy outside-policy interface outside
service-policy inside-policy interface inside
prompt hostname context
call-home reporting anonymous
Cryptochecksum:a31062de89ab14e1b8659eae7a8155de
: end
Hi Kelvin,
By design ASA would not allow you to ping an interface IP if you come from a different interface.
For security purposes the security appliance does not support far-end interface ping, that is pinging the IP address of the outside interface from the inside network.
Here is the document for the same:
http://www.cisco.com/c/en/us/td/docs/security/asa/asa83/asdm63/configuration_guide/config/access_management.html#wp1214986
Aditya
Please rate helpful posts and mark correct answers.
But my pc 10.10.1.9 can't ping any address .
Did i set my NAT rules wrong?
My problem is inside address can't ping any outside address,even i have set the nat rules.
NAT rules are fine.
Share the packet tracer output :
packet-tracer input inside icmp 10.10.1.9 8 0 4.2.2.2 det
Aditya
Phase: 1
Type: ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
Additional Information:
found next-hop 192.168.1.1 using egress ifc  outside
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
 service-object ip
 service-object icmp
 Forward Flow based lookup yields rule:
 in  id=0x7f43d3008750, priority=13, domain=permit, deny=false
        hits=491, user_data=0x7f43ccd7ebc0, cs_id=0x0, use_real_addr, flags=0x0,        protocol=0
        src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, dscp=0x0
        input_ifc=inside, output_ifc=any
Phase: 3
Type: NAT
Subtype:
Result: ALLOW
Config:
nat (inside,outside) after-auto source dynamic obj_any interface dns
Dynamic translate 10.10.1.9/0 to 192.168.1.90/24740
 in  id=0x7f43d2480ef0, priority=6, domain=nat, deny=false
        hits=0, user_data=0x7f43d318cef0, cs_id=0x0, flags=0x0, protocol=0
        src ip/id=10.10.1.0, mask=255.255.255.0, port=0, tag=any
        input_ifc=inside, output_ifc=outside
Phase: 4
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
 in  id=0x7f43d18fefc0, priority=0, domain=nat-per-session, deny=true
        hits=108033, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0        , protocol=0
        input_ifc=any, output_ifc=any
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
 in  id=0x7f43d23fb050, priority=0, domain=inspect-ip-options, deny=true
        hits=7644, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
 class inside-class
  inspect icmp
 in  id=0x7f43d3034780, priority=72, domain=inspect-icmp, deny=false
        hits=1, user_data=0x7f43d249a500, cs_id=0x0, use_real_addr, flags=0x0, p        rotocol=1
        src ip/id=0.0.0.0, mask=0.0.0.0, icmp-type=0, tag=any
        dst ip/id=0.0.0.0, mask=0.0.0.0, icmp-code=0, tag=any, dscp=0x0
Phase: 7
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
 in  id=0x7f43d249d230, priority=72, domain=inspect-icmp-error, deny=false
        hits=1, user_data=0x7f43d249c630, cs_id=0x0, use_real_addr, flags=0x0, p        rotocol=1
Phase: 8
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
 class outside-class
  inspect icmp
 out id=0x7f43d302be30, priority=72, domain=inspect-icmp, deny=false
        hits=5, user_data=0x7f43d302a9d0, cs_id=0x0, flags=0x0, protocol=1
        input_ifc=any, output_ifc=outside
Phase: 9
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
 out id=0x7f43d302f800, priority=72, domain=inspect-icmp-error, deny=false
        hits=5, user_data=0x7f43d302d960, cs_id=0x0, flags=0x0, protocol=1
Phase: 10
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
 out id=0x7f43d320fe00, priority=6, domain=nat-reverse, deny=false
        hits=1, user_data=0x7f43cfc3a660, cs_id=0x0, use_real_addr, flags=0x0, p        rotocol=0
Phase: 11
Type: NAT
Result: ALLOW
Config:
 Reverse Flow based lookup yields rule:
        hits=108035, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0        , protocol=0
Phase: 12
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
 in  id=0x7f43d2394270, priority=0, domain=inspect-ip-options, deny=true
        hits=40260, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
        input_ifc=outside, output_ifc=any
Phase: 13
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 44469, packet dispatched to next module
Module information for forward flow ...
snp_fp_tracer_drop
snp_fp_inspect_ip_options
snp_fp_inspect_icmp
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Module information for reverse flow ...
snp_fp_tracer_drop
snp_fp_translate
snp_fp_inspect_icmp
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Result:
output-interface: outside
output-status: up
output-line-status: up
Action: allow
Can you please remove this config :
no service-policy outside-policy interface outside
no service-policy inside-policy interface inside
Also are you able to ping 192.168.1.1 ?
Can you check the arp on the ASA ?
show arp
Aditya
My firewall can ping 192.168.1.1 , can ping 8.8.8.8 , can ping 10.10.1.9 , can ping 10.10.1.1.here is my arp table as below.
After
But my pc 10.10.1.9 still can't ping any address.
Aditya
HEY!!!
THANK YOU SO MUCH!!!
after i type the dns 4.2.2.2 i can access the internet now!!
thank you so much!!
Hi kelvin,
Glad to assist.
I would request you to close the discussion.
Aditya
