Cant connect from management port to asdm web interface asa5520 F/W
JodyPetroni
Hi Community
I am trying to connect to the ASDM web interface from a PC connected directly to the management port of the ASA5520.
Below is the configuration: -
1. asdm
2. Management Interface
3. http Server
4. On the PC I have connected a cat6 ethernet cable directly to the management port on the FW. I have given a static IP address of 192.168.5.100. I can ping 192.168.5.1 but I get this
whats going on? what have I missed?
thanks
JP
10 Replies 10
try http:// not https://
tried that too
check below comment
Already did that!
I feel as though its something to do with the TLS version on the ASA FW
https://www.cisco.com/c/en/us/td/docs/security/asa/compatibility/asamatrx.html
first let check the compatibility.
check link above for compatibility between ASDM and ASA ver.
share the following
ASAa# show run all ssl
looked promising but alas same browser error
ok solved downloadig the activation key for 3DES-AES worked for me
