Changing Interface Level
rajesh1331
Level 3
Level 3
Hi..
I have a PIX with 5 Intefaces at present. There is an Inside zone with security level 100 and another zone 'A' with security level 99.The next zone comes with security level 80 only.
I would like to add a new 6th Interface with a security level in between Inside and level 'A'. The PIX is operational . Can I reduce the secutiry level of 'A' to say 95 and give the new interface a security level of 98. will the PIX take in the command, and if does will it cause any issues.
rgds
Rajesh
wharrison2000
Level 2
Level 2
Rajesh,
In short the answer is yes! The security-level command with take effect on each new packet put into the state table. However a quick reboot is always best if possible
Bill
wharrison2000
Level 2
Level 2
Rajesh,
Bill
Thank You Bill....
