Cisco 6516 FWSM Module problem
dalia.elmassery
We have a 6513 cisco FW with 2 FWSM Active /Standby Failover , When The primery module is in active state the users sessions is suddenly  disconnected while the ping is OK (no request time packet ) now we have to work with only one module , what should we do.
Thankx
Dalia
Julio Carvajal
Hello Dalia,
Could you explain the issue a litle further???
Are you saying that when having both FWSM in active/standby and with the primary in active state all of the sessions are dropped except ICMP?
Looking for some Networking Assistance?
Contact me directly at jcarvaja@laguiadelnetworking.com
I will fix your problem ASAP.
Cheers,
Julio Carvajal Segura
http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
We found out that the 2 modules becomes in secondery state , we dont know how this happend ,Is that make session dropped ??  we will change the state from secondery to priemary and see if the problem is solved and tell you back.
Thankx
Dalia
We will need to check the Failover configuration to make sure everything is properly configured and ofcourse check connectivity cause the keepalives might not be working.
Let us know.
Cheers,
Julio Carvajal
The problem is solved as soon as the conifguration of the primary module  is changeg to primary instead of secondery , I thought thet the problem is happend when we have to upload a backup , it was the backup of secondary loaded on primary  and we didnt see that it was a wrong one
Thankx
Dalia
