Hi all,
I have problem with negotiating IP address from PPPoE. There is following design: ISP providing vDSL ending on VDSL modem in bridge mode. Behind brigde modem is ASA 5505 terminting PPPoE on OUTSIDE. Everything works fine except negotiating IP address from PPPoE server.
I have configured ASA 5505 with (ASA Version 9.2(2)4) for PPPoE like this [1.]. But If i try to "show" IP address on OUTSIDE interface a get this [2.], ok strange but let's continue. If list "show vpdn pppinterface id 1" i get this [3.]. Seems that I got public IP addres what was right, but this IP address was not associated with interface OUTSIDE?
Well, if I set IP address manually like this [4.] and also set a default route everything works fine but what will happen when ISP change reservation for my IP address or default gateway.
I have tried different version of ASA OS like 8.4, 9.1 but without luck.
Can anybody help me. Thanks a lot.
Karel
[1.]
interface Vlan100
description >>VLAN pro pripojeni do internetu<<
nameif OUTSIDE
security-level 0
pppoe client vpdn group O2
ip address pppoe setroute
vpdn group O2 request dialout pppoe
vpdn group O2 localname O2
vpdn group O2 ppp authentication chap
vpdn username O2 password *****
interface Ethernet0/0
description >>uplink O2 vDSL<<
switchport access vlan 100
[2.]
ciscoasa(config-if)# show ip address vlan 100 pppoe
ciscoasa(config-if)# 0.0.0.0 255.255.255.255 on Interface: OUTSIDE
ciscoasa(config-if)# show interface vlan 100 detail
Interface Vlan2 "OUTSIDE", is up, line protocol is up
Hardware is EtherSVI, BW 100 Mbps, DLY 100 usec
Description: >>VLAN pro pripojeni do internetu<<
MAC address f44e.05d0.6c17, MTU 1492
IP address unassigned
Traffic Statistics for "OUTSIDE":
28 packets input, 1307 bytes
31 packets output, 721 bytes
0 packets dropped
1 minute input rate 0 pkts/sec, 3 bytes/sec
1 minute output rate 0 pkts/sec, 1 bytes/sec
1 minute drop rate, 0 pkts/sec
5 minute input rate 0 pkts/sec, 0 bytes/sec
5 minute output rate 0 pkts/sec, 0 bytes/sec
5 minute drop rate, 0 pkts/sec
Control Point Interface States:
Interface number is 15
Interface config status is active
Interface state is active
[3.]
ciscoasa(config-if)# show vpdn pppinterface id 1
PPP virtual interface id = 1
PPP authentication protocol is CHAP
Server ip address is 88.103.200.41
Our ip address is 85.71.188.158
Transmitted Pkts: 20, Received Pkts: 16, Error Pkts: 0
MPPE key strength is None
MPPE_Encrypt_Pkts: 0, MPPE_Encrypt_Bytes: 0
MPPE_Decrypt_Pkts: 0, MPPE_Decrypt_Bytes: 0
Rcvd_Out_Of_Seq_MPPE_Pkts: 0
ciscoasa(config-if)# show vpdn session state
%No active L2TP tunnels
%No active PPTP tunnels
PPPoE Session Information (Total tunnels=1 sessions=1)
SessID TunID Intf State Last Chg
22298 2 OUTSIDE SESSION_UP 561 secs
[4.]
interface Vlan100
nameif OUTSIDE
security-level 0
ip address 85.71.188.158 255.255.255.255 pppoe setroute
route OUTSIDE 0.0.0.0 0.0.0.0 88.103.200.41 1
