CISCO ASA 5505 WITH 2 PPPOE CONNECTION
kaushal22
I am using cisco asa 5505 with 9.2(3) asa version. I want to use it as dual wan both PPPOE but only one PPPOE Works at a time.
Here is what i have created.
Two VPDN GROUP one for each PPPOE Connection.
Outside1 --- Vlan2
Outside2---Vlan999
If i get ip on outside1 using pppoe then outside2 does not work  and if i disconnect outside1 and restart the asa then i will get IP on Outside2.
Is there a way to fix this issue ?
Just a guess: One of your vlan-interfaces (where you apply your "pppoe client vpdn group XXX") is missing the command
 pppoe client route distance 100
With that you change the administrative distance of the default route on the secondary line to 100. This one can now be used for incoming connections and also as backup for outgoing connections if the first line fails.
Karsten,
I have used this command on both vlan interfaces. But i just keep the same distance for both.
I used pppoe client route distance 2 for both.
One of the VLans (the secondary link) needs to have a higher distance. They can't be of the same value.
Karsten,
Still only one int. gets an ip.
Here is what i change.
___________________________________________
outside1---vlan999
Ip dhcp pppoe setroute
outside2---vlan2
Ip dhcp pppoe
ANY SUGGESTIONS ??
