09-23-2020 01:25 PM
Hello, i turned on afte a few weeks and it doesn't see internet.here's the show run
ciscoasa# show run
: Saved
: Serial Number: JMX1225L1LS
: Hardware: ASA5510, 1024 MB RAM, CPU Pentium 4 Celeron 1600 MHz
ASA Version 9.1(7)32
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/1
nameif inside
security-level 100
ip address 10.0.0.2 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
boot config disk0:/startup-1.cfg
ftp mode passive
pager lines 24
mtu outside 1500
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
no snmp-server location
no snmp-server contact
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpoint _SmartCallHome_ServerCA
no validation-usage
crl configure
crypto ca trustpool policy
telnet timeout 5
ssh stricthostkeycheck
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd dns 208.67.222.222 208.67.220.220
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
prompt hostname context
call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:adfe96de0173c0b922d5ee0831e5639e
: end
ciscoasa#
i must say that i havent changed anything and tried to copy the backup config from the flash.what's wrong?i use opendns.
Solved! Go to Solution.
10-08-2020 04:59 PM
ciscoasa(config)# show interface
Interface Ethernet0/0 "outside", is up, line protocol is up
Hardware is i82546GB rev03, BW 1000 Mbps, DLY 10 usec
Full-Duplex(Full-duplex), 100 Mbps(100 Mbps)
Input flow control is unsupported, output flow control is off
MAC address 0021.554f.35bc, MTU 1500
IP address 192.168.1.9, subnet mask 255.255.255.0
7 packets input, 2568 bytes, 0 no buffer
Received 3 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 pause input, 0 resume input
0 L2 decode drops
8 packets output, 2632 bytes, 0 underruns
0 pause output, 0 resume output
0 output errors, 0 collisions, 2 interface resets
0 late collisions, 0 deferred
0 input reset drops, 0 output reset drops, 0 tx hangs
input queue (blocks free curr/low): hardware (255/254)
output queue (blocks free curr/low): hardware (255/254)
Traffic Statistics for "outside":
7 packets input, 2442 bytes
8 packets output, 2416 bytes
0 packets dropped
1 minute input rate 0 pkts/sec, 20 bytes/sec
1 minute output rate 0 pkts/sec, 19 bytes/sec
1 minute drop rate, 0 pkts/sec
5 minute input rate 0 pkts/sec, 0 bytes/sec
5 minute output rate 0 pkts/sec, 0 bytes/sec
5 minute drop rate, 0 pkts/sec
Interface Ethernet0/1 "inside", is up, line protocol is up
MAC address 0021.554f.35bd, MTU 1500
IP address 10.1.1.2, subnet mask 255.255.255.0
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 L2 decode drops
3 packets output, 192 bytes, 0 underruns
ciscoasa(config)# ping 1.1.1.1
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 10/14/20 ms
10-08-2020 05:00 PM
Anyone can tell me what is wrong and i don't have internet access?i still havent setup dhcp and dns though.
10-15-2020 01:45 AM
i fixed it myself, thanks anyway.
10-15-2020 04:21 PM
object network inside
subnet 10.1.1.0 255.255.255.0
nat (inside,outside) dynamic interface
