Cisco ASA 5510 high memory usage problem
ovic
Community Member
Hi all,
in our network we have a Cisco ASA 5510, 256 MB RAM, running on ios verison 8.2(5)48. The problem that started around 10 days ago includes exceptionally high memory usage (around 85-87% which is a considarable spike as before it was no more then 50%). This memory usage stays around this percent the whole time and lowers for several percent at low business hours (but still remains high compering to prior times). The thing that needs to be pointed out is that so far no user and no device that uses this firewall to pass traffic hasn't reported any issue. The problem is that this ASA is not redundant and if at some point it fails do to this memory situation there will be a break in communication.
Show memory commands reviled several troubling data, but I am not sure how to decipher them so I am turning to you guys 🙂 Here are the commands:
show memory
Free memory:        33063656 bytes (12%)
Used memory:       235371800 bytes (88%)
Total memory:      268435456 bytes (100%)
show memory detail
Free memory:                      33112696 bytes (12%)
Used memory:
     Allocated memory in use:     92716424 bytes (35%)
     Reserved memory:            142606336 bytes (53%)
Dynamic Shared Objects(DSO):          0 bytes
Least free memory:          51512 bytes ( 0%)
Most used memory:       268383944 bytes (100%)
MEMPOOL_DMA POOL STATS:
Non-mmapped bytes allocated =   53248000
Number of free chunks       =         66
Number of mmapped regions   =          0
Mmapped bytes allocated     =          0
Max memory footprint        =   53248000
Keepcost                    =   33063984
Max contiguous free mem     =   33063984
Allocated memory in use     =   20180936
Free memory                 =   33067064
----- fragmented memory statistics -----
 fragment size       count          total
    (bytes)                        (bytes)
           24            13            312
           32             2             64
           40            16            640
           48             1             48**
           48            31           1488
           64             1             64
           80             1             80
     33063984             1       33063984*
*  - top most releasable chunk.
** - contiguous memory on top of heap.
----- allocated memory statistics -----
    (bytes)                        (bytes)
           48             2             96
           56          1389          77784
           64            52           3328
           72             1             72
           80             6            480
          112             7            784
          120             3            360
          144             6            864
          168             2            336
          232             1            232
          248             1            248
          256             5           1280
          384             3           1152
          512             6           3072
         1024            98         100352
         2048             1           2048
         4096             4          16384
         8192            12          98304
        16384             1          16384
        24576             2          49152
        32768             3          98304
        65536             6         393216
        98304             1          98304
       131072             1         131072
       196608             2         393216
       262144             3         786432
       393216             1         393216
       524288             3        1572864
       786432             1         786432
      1048576             2        2097152
      1572864             1        1572864
      2097152             1        2097152
      6291456             1        6291456
MEMPOOL_GLOBAL_SHARED POOL STATS:
Non-mmapped bytes allocated =  125829120
Number of free chunks       =       2198
Max memory footprint        =  125829120
Keepcost                    =       1248
Max contiguous free mem     =     262264
Allocated memory in use     =   92717784
Free memory                 =   33111336
    (bytes)                        (bytes)
           16           159           2544
           24           210           5040
           32            82           2624
           40            71           2840
           48             1             48**
           48            96           4608
           56            37           2072
           64            28           1792
           72            49           3528
           80            22           1760
           88            41           3608
           96            18           1728
          104            18           1872
          112            15           1680
          120            22           2640
          128            18           2304
          136            24           3264
          144            15           2160
          152            19           2888
          160            19           3040
          168            20           3360
          176            26           4576
          184             9           1656
          192             9           1728
          200            12           2400
          208            15           3120
          216            11           2376
          224            12           2688
          232            15           3480
          240             8           1920
          248             9           2232
          256           159          44808
          384            10           4624
          512           113          67304
          768            38          34632
         1024            15          18928
         1248             1           1248*
         1536            13          20904
         2048             7          17216
         3072            80         292616
         4096           114         598168
         6144            93         663344
         8192            97         937496
        12288            18         247896
        16384            21         415288
        24576             1          25232
        32768             1          37776
        65536           261       21939920
        98304             9         946712
       131072            34        5734600
       196608             2         456632
       262144             2         524864
    (bytes)                        (bytes)
           48          1394          66912
           56           738          41328
           64          4380         280320
           72           359          25848
           80          3672         293760
           88           387          34056
           96           251          24096
          104          1962         204048
          112           957         107184
          120           506          60720
          128           586          75008
          136          3291         447576
          144           110          15840
          152          1065         161880
          160           171          27360
          168           257          43176
          176           193          33968
          184          1738         319792
          192          1100         211200
          200           259          51800
          208             5           1040
          216            45           9720
          224            24           5376
          232            33           7656
          240           285          68400
          248           150          37200
          256         11722        3000832
          384           644         247296
          512          1524         780288
          768            33          25344
         1024           638         653312
         1536            17          26112
         2048           772        1581056
         3072            65         199680
         4096           111         454656
         6144            13          79872
         8192            87         712704
        12288            35         430080
        16384           429        7028736
        24576            67        1646592
        32768            38        1245184
        49152             9         442368
        65536           567       37158912
        98304             2         196608
       131072            17        2228224
       196608             3         589824
       262144             6        1572864
       393216             4        1572864
       524288             7        3670016
       786432             5        3932160
      1048576             1        1048576
      1572864             1        1572864
      2097152             3        6291456
Summary for all pools:
Non-mmapped bytes allocated =  179077120
Number of free chunks       =       2264
Max memory footprint        =  179077120
Keepcost                    =   33065232
Allocated memory in use     =  112898720
Free memory                 =   66178400
And finally the one which shows some failed parts:
show memory app-cache
          CACHE NAME   LIMIT      COUNT      ALLOC     FAILED   BYTES USED
         Local block    1024                  251             251          0                216864
         NP dispatch     325          1                          134          0                 32696
            SNP Conn     325        261                    7774     79469508      5597280
        netflow data     325          0          0          0            0
                DSCP     325          0          0          0            0
            SNP Host     325        304       4620   16467386       868560
 SNP conn set per-cl     325          0          0          0            0
          SNP APP ID     325        283        326        270        32600
      SNP RT Inspect     325        279        326         35        76936
    NP-CP punt event     325          0          0          0            0
 NP-CP identity-traf     325          0          0          0            0
         NP-CP event     325          0          0          0            0
  NP-CP syslog event     325          0          0          0            0
 NP-CP midpath event     325          0          0          0            0
    NP-CP SRTP event     325          0          0          0            0
      NP-CP ha event     325          0          0          0            0
      NP-CP TD event     325          0          0          0            0
      NP ACL log cfg     325          0         43          0         2924
     NP ACL log flow     325        230       1584      20827       297792
             SNP TCB     325        282       4724          0      1209344
    SNP Logger block     325          0          0          0            0
       SNP MP PF Mod     325          0          0          0            0
     SNP MP SVC Conn     325          0          0          0            0
     SNP SVC Session     325          0          0          0            0
      SNP MP Service     325          0          0          0            0
        SNP MP Stack     325          1          3          0         1416
       TD Rate stats     500          0         62          0         9424
       TD Port stats     100          0          0          0            0
 TD Host/Port counte     100          0          0          0            0
         CTM SG List    5000          0          0          0            0
  CERT API msg cache     100          0          0          0            0
       CP Connection     325        322        329     622489       252672
           CP APP ID     325          0          0          0            0
         PM Bit Mask     325          1          1          0           56
       PM Hash table     325          0          0          0            0
        Inspect HTTP     325          0          0          0            0
         HTTP Result     325          0          0          0            0
        TD ACE stats     100          0         20          0         5040
 TD Host/Port counte     100          0         20          0          480
           TOTAL       17099       2215      20217   96580515      8604084
As you can see there are a lot of FAILED numbers in this column but I am not certain what do they mean, and I haven't been able to find much about them on the internet. So if someone had a similiar problem or can advise in some way I would appriciate it.
Best regards,
Stevan
5 Replies 5
Vibhor Amrodia
I think there is something wrong.
Check this:-
show memory detail
Used memory:
Share the ASA show tech
Rest , get this output:-
show mem binsize 65536
Thanks and Regards,
Vibhor Amrodia
Hi Vibhor,
thanks for the answer. Yup it is true this procent for reserved memory constantly stays at that 53% procent, but I thought the failed numbers my point more accurately to the problem, as they do seem pretty specific. I can't post show tech now but here is show mem binisize 65536 output
show memory binsize 65536
MEMPOOL_DMA pool bin stats:
pc = 0x0812b386, size = 65607    , count = 1
pc = 0x0804f0c4, size = 159022   , count = 2
pc = 0x0804f669, size = 249813   , count = 3
MEMPOOL_GLOBAL_SHARED pool bin stats:
pc = 0x09337e6e, size = 44710685 , count = 571
pc = 0x0817680d, size = 262448   , count = 4
pc = 0x08a00960, size = 81920    , count = 1
pc = 0x08c6cff8, size = 7665568  , count = 110
pc = 0x08ad33d9, size = 199008   , count = 3
pc = 0x088fdf2f, size = 91064    , count = 1
pc = 0x0933810a, size = 297116   , count = 4
pc = 0x081e9144, size = 65536    , count = 1
pc = 0x08141928, size = 139264   , count = 2
pc = 0x08141668, size = 69632    , count = 1
pc = 0x08e02e55, size = 65536    , count = 1
pc = 0x08782077, size = 96064    , count = 1
pc = 0x087300af, size = 65536    , count = 1
pc = 0x08c631cb, size = 163968   , count = 2
pc = 0x08531c2d, size = 71136    , count = 1
pc = 0x08aab363, size = 66048    , count = 1
pc = 0x0804fb6c, size = 66496    , count = 1
pc = 0x0804fb97, size = 66496    , count = 1
Generally I was hoping that someone had the same issue, so he could give advice as to what is happening. If not I will open a Cisco TAC, so far this has not caused any real problems but it definitly needs to be checked.
If you have any more input or ideas please share.
Best regards,
Stevan
I think it would be best that you open a TAC. I think you should focus on the Reserved RAM issue.
Thanks and Regards,
Vibhor Amrodia
Hi Stevan ,
I hope that you are well . Have you resolved this issue. I am experiencing a similar issue.
Hi I actually completly forgot about this thread.
Anyway just to write for anyone that stumbels upon it like Dhiran here:
In the end I opened a TAC case, we didn't find the couse for this, but upon advise from TAC engineer an upgrade to newer version of IOS helped resolve the issue completly.
Stevan
