CISCO ASA 5510 PROBLEM
antrikos_kal
Level 5
Level 5
Hi people.Please can you help me?I erased disk0 and whenever i upload the ios after a reboot it doesn't boot while when the ios is uploaded works ok.Did i miss a command that i have to type to save it?show flash doesn't show the ios installed.
7 Replies 7
Marius Gunnerud
is the image being removed when you reboot the ASA?  Do you get to ROMMON on the reboot?  If you check flash (dir) in ROMMON before you upload a new OS image, do you see the OS image there?
have you tried adding the command boot system disk0:/<image name>  (replace <image name> with the actual name of the OS image as it appears in flash including .bin)
Please remember to select a correct answer and rate helpful posts
The image doesn't show up in show flash at all only some coredump etc when i upload the ios.
have you tried running a file system check on the ASA?
fsck flash:
or
fsck disk0:
yes all ok.
It all happened when i erased disk0, it was working all ok before.
If disk0: is not able to retain files then there is a problem with it.  If fcsk disk0: does not help then I would suggest opening a support case with Cisco as this might be an RMA case.
οκ
