Cisco ASA 5512-x has problem with mulit Wan(ISP)
rechard_david
Dear All,
I have Cisco ASA 5512-x and have 3 ISP. i don't know how to confiure on ASA 5512-x with muliple ISP. all 3 ISP i would like to active the same time.
Could you advice or have some idea?
Please help!!!
Best Regards,
Rechard
Julio Carvajal
That is not possible unless all of them go out the same interface ( witch is not going to happen )
You cannot have more than one route pointing to the same destination going out on different interfaces and active at the same time.
Sorry to inform you that , you could use SLA but is for redundancy purposes
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806e880b.shtml
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Dear Jcarvaja,
Thank you for you advice!
you mean ASA 5512-x cannot do Active multive Wan connection right? but it can do only Active/Stand Wan ....
Is it possible if i have other vender (Pep Link) for connect to internet and the lan Pep link connect to ASA ?
I mean that All (3 ISP) connect to Pep link for load balacing and Pep link connect to ASA 5512-x and ASA 5512-x connet to my Lan.
Best Regards,
Rechard.
Dear All,
Do you have any update or advice on this?
Best Regards,
Rechard
