05-03-2022 01:18 AM
Hello Everyone,
I want to ask a quetion.
We have a Cisco ASA 5525.
The equipment has never been turned off but,
If it look at the operating hours of the equipment(device up time) in ASDM, it turned off and on a few days ago.
we already runed Cisco CLI analyzer tool, but nothing find.
Why it have these symptoms?
We need to find if it is possible that reason.
Is there any way to know why these symptoms appear?
Please let me know if there is a good way. I beg you
Thank You ,
05-03-2022 01:50 AM
show verion show you the updatime, if you do not have configured any syslog server, then you may not able to find the reason why it was reloaded ?
05-03-2022 04:55 PM
Thank you for your answer.
Let me check.
05-03-2022 04:12 AM
Asa Show version command
Reload reason <-
05-03-2022 04:56 PM
05-04-2022 01:55 AM - edited 05-04-2022 01:56 AM
You will not see on ASA reload reason, as per i know, since there is no Logs stopred on device (you may not able to find that information)
until we look any more Logs we see in flash.
how long was the uptime before it rebooted ?
9.6.X code is quite old, may be uplift and observ.
Other note, what you see logs on the switch it connected this ASA , is the switch also rebooted ?
if you really more keen to understand the issue and have support Raise TAC Case.
05-08-2022 06:07 PM
In effect, the equipment was not rebooted.
However, the equipment operating time was initialized in ASDM.
So I want to know why
05-03-2022 09:42 PM
hi,
can you share a 'show crashinfo' output.
if there's no crashinfo output, i would suggest to use/transfer to more a stable power source or better use UPS.
05-08-2022 06:05 PM - edited 05-08-2022 06:13 PM
I will share it with you when I extract the 'crashinfo'.
thank you
