Cisco asa 5525x transparent mode trouble please help me
haluksamatli1
I have an HP 5406 r zl2 switch and Cisco ASA 5525-x device.  Is it necessary to define an IP or vlan in transparent mode on  this devices?Or is it needed to make a specific configuration?I just could define inside and outside interfaces. isnt it sufficient
nspasov
Hi there-
You need IP addresses for management purposes. Please check out the ASA configuration guide below and let us know if you have any questions:
http://www.cisco.com/c/en/us/td/docs/security/asa/asa95/configuration/general/asa-95-general-config/intro-fw.html#ID-2106-00000004
Thank you for rating helpful posts!
is it sufficient?
All bridge groups needs to have an IP configured.
Please remember to select a correct answer and rate helpful posts
so long as the 92.45.63.1/29 is in the same subnet as that which is on the inside and outside of the ASA then that is all you need for the BVI part.
