Cisco ASA 5540 - Access to outside interface from device inside network
cocoengineers
Hello All
ASA Newbie
Using ASA 9.0 -
Need to know if this is possible without compromising security -
This is our scenario -
Inside our network we have a "public access" wireless network, this is set up on a Cisco 5508 with the appropriate ACLs at the core to block the public wireless network from accessing internal resources.
We can We now are trying to allow the users on the "public" network to access our VPN gateway which happens to be the same IP address on our ASA outside interface.
How do I allow that traffic from the public network to access the VPN gateway if its coming back in the same way it came out? I assume it would be a NAT.
Thanks in advance
Jose
rvarelac
Level 7
Level 7
Hi Jose,
Unfortunately this is behavior is not allowed by the ASA, Let's take an example the below topology.
10.1.1.0/24 --- WLAN interface--ASA--Outside interface (VPN) ----- internet.
In this way the users behind the WLAN interface won't be able to VPN to the outside interface , this is due to the security rules on the ASA  and this behavior can't be changed.  Alternative you can enable the VPN on the WLAN and Outside interface simultaneously.
Hope it helps
-Randy-
rvarelac
Level 7
Level 7
Hi Jose,
Hope it helps
-Randy-
Randy
Thanks for the reply. We are now looking at the alternative action.
