12-03-2015 07:34 AM - edited 03-11-2019 11:59 PM
I'm going to replace ASA 5550 in active/standby failover configuration. I'm going to replace the primary unit. I moved the flash from the damaged one to the new one. Everityng was ok. Actually one thins is different, the I guess "new" one have 100 AnyConnect Premium Peers more than the old one. Can this prejudice correct failover behaviour ? I do not use vpn.
Secondary ASA:
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited perpetual
Maximum VLANs : 400 perpetual
Inside Hosts : Unlimited perpetual
Failover : Active/Active perpetual
Encryption-DES : Enabled perpetual
Encryption-3DES-AES : Enabled perpetual
Security Contexts : 2 perpetual
GTP/GPRS : Disabled perpetual
AnyConnect Premium Peers : 2 perpetual
AnyConnect Essentials : Disabled perpetual
Other VPN Peers : 5000 perpetual
Total VPN Peers : 5000 perpetual
Shared License : Disabled perpetual
AnyConnect for Mobile : Disabled perpetual
AnyConnect for Cisco VPN Phone : Disabled perpetual
Advanced Endpoint Assessment : Disabled perpetual
UC Phone Proxy Sessions : 2 perpetual
Total UC Proxy Sessions : 2 perpetual
Botnet Traffic Filter : Disabled perpetual
Intercompany Media Engine : Disabled perpetual
Cluster : Disabled perpetual
This platform has an ASA 5550 VPN Premium license.
Failover cluster licensed features for this platform:
Security Contexts : 4 perpetual
AnyConnect Premium Peers : 4 perpetual
UC Phone Proxy Sessions : 4 perpetual
Total UC Proxy Sessions : 4 perpetual
ASA primary (replaced one):
AnyConnect Premium Peers : 100 perpetual
AnyConnect Premium Peers : 102 perpetual
Solved! Go to Solution.
12-04-2015 03:14 AM
If your ASA version is above 8.3.1 then you should not face any issue.
Failover units do not require the same license on each unit.
Older versions of ASA software required that the licenses match on each unit. Starting with Version 8.3(1), you no longer need to install identical licenses. Typically, you buy a license only for the primary unit; for Active/Standby failover, the secondary unit inherits the primary license when it becomes active. If you have licenses on both units, they combine into a single running failover cluster license.
The exceptions to this rule include:
•Security Plus license for the ASA 5505, 5510, and 5512-X—The Base license does not support failover, so you cannot enable failover on a standby unit that only has the Base license.
•Encryption license—Both units must have the same encryption license.
For more information you can refer "Failover Licenses (8.3(1) and Later)" section of the below document
http://www.cisco.com/c/en/us/td/docs/security/asa/asa84/configuration/guide/asa_84_cli_config/intro_license.html#wp2153381
Shivapramod M
Please remember to select a correct answer and rate helpful posts
12-04-2015 03:14 AM
Shivapramod M
12-04-2015 07:13 AM
great, thanks for your answer.
