Cisco ASA 8.6 - Static PAT with same Public IP
abhisar patil
Dear Team,
Please help me to configure static PAT with same Public IP. I did some configuration but did not worked.
Public IP - 1.1.1.1
Private IP1  - 192.168.1.10 Port http
Private IP1  - 192.168.1.20 Port SMTP
Configuration -
object network obj-192.168.1.10
  host 192.168.1.10
  host 192.168.1.10
object network obj-1.1.1.1
  host 1.1.1.1
object service HTTP
service tcp source eq http
object service SMTP
service tcp source eq SMTP
nat (inside,outside) source static obj-192.168.1.10 obj-1.1.1.1 service HTTP HTTP
nat (inside,outside) source static obj-192.168.1.20 obj-1.1.1.1 service SMTP SMTP
acces-list outside extended permit tcp any host 192.168.1.10 eq http
Thank You,
Abhisar.
5 Replies 5
pubhanda
Hi Abhisar,
This would be the configuration which would help you in solving acheiving your requirement.
  host 192.168.1.10
object network obj-192.168.1.20
  host 192.168.1.20
  host 1.1.1.1
object service HTTP
object service SMTP
access-list outside extended permit tcp any host 192.168.1.10 eq http
access-list outside extended permit tcp any host 192.168.1.20 eq smtp
The above access-list "outside" should be applied to the outside interface with the help of following command:
access-group outside in interface outisde
Thank you,
Pulkit Bhandari
Dear Pulkit,
Thank you for your reply. I have applied that access-group, I did not pasted here. I want to know about nat configuration if it is correct or not?
Thank You,
Abhisar.
Hi Abhisar,
Yes, i did checked the configuration and found some errors. It might be a Typing error though..
  host 192.168.1.10
object network obj-192.168.1.10                                   it should be for 192.168.1.20
  host 192.168.1.10
  host 1.1.1.1
object service HTTP
object service SMTP
acces-list outside extended permit tcp any host 192.168.1.10 eq http         ---> this should be also for 192.168.1.20 for smtp
The corrected configuration should be as follows:
  host 192.168.1.10
  host 192.168.1.20
  host 1.1.1.1
object service HTTP
object service SMTP
Hope this helps
Please  do remember to mark a reply as the correct answer if it answered your question.
Feel free to ask more if needed
Pulkit Bhandari
Dear Pulkit,
Thank you for your reply and correction . This is typing error from my side, what about the logic behind the configuration if is it fine?
Thank You,
Abhisar.
Hi Abhisar,
Yes, the logic behind the configuration is correct.
For more details regarding the new  NAT configuration on ASA version 8.3+ you can also refer the following documents:
https://supportforums.cisco.com/docs/DOC-12690
Hope this helps.
- Pulkit
