Cisco ASA 9.4 PBR with Cache Flow and PBR
ivan.martin
I need to connect a device to make Internet cache (CacheFlow) with a single interface using a Cisco ASA Firewall PBR to redirect user traffic on the LAN. The device that makes cache, necessarily requires the PB
The flow of information must start from the inside, get to the ASA interface called CacheFlow, CacheFlow leave the team and return in the same interface, and finally reach the outside.
Similarly to enter Internet. The firewall is version 9.4.1.
Please could you help me?.
Regards, Ivan.
Rishabh Seth
Level 7
Level 7
Hi Ivan,
Can you provide some details about your requirements.
http://www.cisco.com/c/en/us/td/docs/security/asa/asa94/configuration/general/asa-general-cli/route-policy-based.html
R.Seth
Hi risseth
I have one device cache flow, and to this example i called C, an array of firewalls in HA, to this example i called F, and one switch core and i called S.
The conexion is...
F is conneted with EtherChannel to S. F have eigrp to announce all the routes. S also have eigrp.
I nned to connect C to F, using one interface, in one zone (cache flow zone) and stablish a PBR, to redirect the traffic from S to the zone cache flow. The cache flow need the PBR. When the traffic arrive to this interface, is necessary that this traffic out to the same interface and arrive to outside.
In the same way from internet to arrive the caceh flow and network lan.
Could you help me to do it please?.
Regards, Ivan.
