Cisco ASA design guide for use with Contexts
I am looking for a design guide for when using contexts.  More specifically when setting up 2 contexts (one for an un-secure zone the second for a secure zone).  Am a little curious on the best practices for routing between the two contexts, as from my understanding the ASA can not route traffic itselft between the two contexts?
We are working with ASA5585's.
Any advice, tips or links would be much appreciated.
Thanks.
Please remember to select a correct answer and rate helpful posts
I personally never did so, but it's possible to pass traffic between context, when using so called cascading. In this case, outisde interface of one context is located on the same phisical interface (shared interface) as the inside interface of another context. Those two interfaces should use different mac-addresses for ASA to be able to classify to wich context packet is directed. Here's the link where it's described a little:
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/contexts.html
But to me it seems more practical and logical not to share any phisical interfaces of the ASA, and direct traffic between context using external switches and additional cables. So say out of four interfaces of one phisical appliance you may bind two to one context and another two to another. For traffic to go between them, just properly connect inside-outside interfaces of corresponding contexts.
Andrew Phirsov
Level 7
Level 7
Why would you need two contexts, if you're planning to pass traffic between them? Firewall in sinlge context mode will perfectly suit your need for separation secure and unsecure segments.
Thanks for your reply.
Yes I know, but we have a requirement that the secure and not secure are to be separeted by "2 different firewalls".
for example:
WAN ----------- outside-ASA ---------- Unsecure client access ------------- inside-ASA ------------- Servers / sensitive information
Now I realize that this can be done with 1 context aka "single mode".  But the client has security policies that state that the secure and unsecure portions of the network need to be separted by 2 seperate firewalls.  To save on costs they have purchased 2 ASA5585 to be used in 2 different data centers, and ustilize the Contexts for the physical separation of the networks.
Now, I am wondering if my understanding of the ASA is incorrect, that it is able to pass traffic from one context to another.  Or, would I need to do a bit of cable magic and use a transport VLAN through the switch to the secure context to get the routing to work?
