Cisco FDM Firepower 1140 drops connection randomly
MXUser
Hi All
We have a Cisco Firepower 1140 on 7.0.1 that drops the local connectivity randomly, it used to be frequent, we did a reboot and no drop for 2 weeks now these are coming again.. how can we troubleshoot this and get the needed logs to know what is happening? again, we have FDM and not FMC managed device.
5 Replies 5
marce1000
 - Connect to the Firepower 1140 , with https://cway.cisco.com/cli/ , then at the top left run 'System Diagnostics' ,
 M.
Hi Marce1000,
Thanks for the reply and the hint about the CLI analyzer, never knew such a nice tool was there.. I can't seem to find System Diagnostic however in the left corner.
Thank you
 - Probably the particular feature is not available for this device , however configure a syslog server on it , and set the log level at debug , follow-up on the logs and look for unusual events , (if any) ,
 M.
MXUser
Logs didn;t show anything particular.. we will try an upgrade to the lates firmware
After these drops became more frequent, Cisco TAC weren;t able to find the root cause, they would see a process being killed but they have no clue what is it.. still the ticket is open with them..
