Cisco FPR-2140 running ASA image showing interface speed 1Gig in ASA CLI and shows 10gig on FXOS CLI
We have a pair of FPR-2140 appliances running asa 9.10 image. The appliance has 4 x 10gig interfaces. If I go to fxos CLI the speed is showing as 10gig on all the four interfaces. But if I check on the ASA CLI it is showing as 1Gig. Does this require any additional license or any additional configuration?. Kindly help
Sheraz.Salim
we are running FTD 2140. FXOS see the 10GB port but ASA does not see it. due to the fact the FXOS is the running on top of the hypervisor and sense what is configure where as ASA code is sitting on top of FXOS so it does not know if its a 1 gb or 10gb it just classified as 1gb. No its not license issue. it more likely a cosmetic thing here. check here give you bit better understanding.
Interface Ethernet1/1 "Outside_Interface", is up, line protocol is up
  Hardware is EtherSVI, BW 1000 Mbps, DLY 10 usec
        MAC address 4ce1.7579.70bd, MTU 1500
        IP address x.x.x.x, subnet mask 255.255.255.240
  Traffic Statistics for "Outside_Interface":
        3980 packets input, 183080 bytes
        61 packets output, 1708 bytes
        0 packets dropped
      1 minute input rate 0 pkts/sec,  0 bytes/sec
      1 minute output rate 0 pkts/sec,  0 bytes/sec
      1 minute drop rate, 0 pkts/sec
      5 minute input rate 0 pkts/sec,  0 bytes/sec
      5 minute output rate 0 pkts/sec,  0 bytes/sec
      5 minute drop rate, 0 pkts/sec
  Control Point Interface States:
        Interface number is 6
        Interface config status is active
        Interface state is active
Interface Ethernet1/2 "Inside_Interface", is up, line protocol is up
        MAC address 4ce1.7579.70ed, MTU 1500
        IP address x.x.x.x, subnet mask 255.255.255.248
  Traffic Statistics for "Inside_Interface":
        26 packets input, 1412 bytes
        26 packets output, 728 bytes
        0 packets dropped
        Interface number is 7
Interface Ethernet1/3 "", is admin down, line protocol is down
        Available but not configured via nameif
Interface Ethernet1/4 "", is admin down, line protocol is down
Interface Ethernet1/5 "", is admin down, line protocol is down
Interface Ethernet1/6 "", is admin down, line protocol is down
Interface Ethernet1/7 "", is admin down, line protocol is down
Interface Ethernet1/8 "", is admin down, line protocol is down
Interface Ethernet1/9 "", is admin down, line protocol is down
Interface Ethernet1/10 "", is admin down, line protocol is down
Interface Ethernet1/11 "", is admin down, line protocol is down
Interface Ethernet1/12 "", is admin down, line protocol is down
Interface Ethernet1/13 "", is admin down, line protocol is down
Interface Ethernet1/14 "", is admin down, line protocol is down
Interface Ethernet1/15 "", is admin down, line protocol is down
Interface Ethernet1/16 "", is admin down, line protocol is down
 /eth-uplink/fabric # show interface
Interface:
    Port Name      Port Type          Admin State Oper State       State Reason
    Ethernet1/1    Data               Enabled     Up               Up
    Ethernet1/2    Data               Enabled     Up               Up
    Ethernet1/3    Data               Disabled    Link Down        Down
    Ethernet1/4    Data               Disabled    Link Down        Down
    Ethernet1/5    Data               Disabled    Link Down        Down
    Ethernet1/6    Data               Disabled    Link Down        Down
    Ethernet1/7    Data               Disabled    Link Down        Down
    Ethernet1/8    Data               Disabled    Link Down        Down
    Ethernet1/9    Data               Disabled    Link Down        Down
    Ethernet1/10   Data               Disabled    Link Down        Down
    Ethernet1/11   Data               Disabled    Link Down        Down
    Ethernet1/12   Data               Disabled    Link Down        Down
    Ethernet1/13   Data               Disabled    Link Down        Down
    Ethernet1/14   Data               Disabled    Link Down        Down
    Ethernet1/15   Data               Disabled    Link Down        Down
    Ethernet1/16   Data               Disabled    Link Down        Down
DC-B5E12-FTD1 /eth-uplink/fabric # show interface detail
Interface:
    Port Name: Ethernet1/1
    User Label:
    Port Type: Data
    Admin State: Enabled
    Oper State: Up
    State Reason: Up
    flow control policy: default
    Auto negotiation: Yes
    Admin Speed: 1 Gbps
    Oper Speed: 1 Gbps
    Admin Duplex: Full Duplex
    Oper Duplex: Full Duplex
    Ethernet Link Profile name: default
    Oper Ethernet Link Profile name: fabric/lan/eth-link-prof-default
    Udld Oper State: Unknown
    Inline Pair Admin State: Enabled
    Inline Pair Peer Port Name:
    Current Task:
    Port Name: Ethernet1/2
    User Label:
    Port Type: Data
    Oper State: Up
    State Reason: Up
    Admin Speed: 1 Gbps
    Oper Speed: 1 Gbps
    Current Task:
    Port Name: Ethernet1/3
    User Label:
    Port Type: Data
    Admin State: Disabled
    Oper State: Link Down
    State Reason: Down
    Admin Speed: 1 Gbps
    Oper Speed: Indeterminate
    Current Task:
    Port Name: Ethernet1/4
    User Label:
    Port Type: Data
    State Reason: Down
    Admin Speed: 1 Gbps
    Current Task:
    Port Name: Ethernet1/5
    User Label:
    Port Type: Data
    State Reason: Down
    Admin Speed: 1 Gbps
    Current Task:
    Port Name: Ethernet1/6
    User Label:
    Port Type: Data
    State Reason: Down
    Admin Speed: 1 Gbps
    Current Task:
    Port Name: Ethernet1/7
    User Label:
    Port Type: Data
    State Reason: Down
    Admin Speed: 1 Gbps
    Current Task:
    Port Name: Ethernet1/8
    User Label:
    Port Type: Data
    State Reason: Down
    Admin Speed: 1 Gbps
    Current Task:
    Port Name: Ethernet1/9
    User Label:
    Port Type: Data
    State Reason: Down
    Admin Speed: 1 Gbps
    Current Task:
    Port Name: Ethernet1/10
    User Label:
    Port Type: Data
    State Reason: Down
    Admin Speed: 1 Gbps
    Current Task:
    Port Name: Ethernet1/11
    User Label:
    Port Type: Data
    State Reason: Down
    Admin Speed: 1 Gbps
    Current Task:
    Port Name: Ethernet1/12
    User Label:
    Port Type: Data
    State Reason: Down
    Admin Speed: 1 Gbps
    Current Task:
    Port Name: Ethernet1/13
    User Label:
    Port Type: Data
    State Reason: Down
    Auto negotiation: No
    Admin Speed: 10 Gbps
    Current Task:
    Port Name: Ethernet1/14
    User Label:
    Port Type: Data
    State Reason: Down
    Current Task:
    Port Name: Ethernet1/15
    User Label:
    Port Type: Data
    State Reason: Down
    Current Task:
    Port Name: Ethernet1/16
    User Label:
    Port Type: Data
    State Reason: Down
    Current Task:
please do not forget to rate.
