Cisco PIX / ASA and DNSSEC problem approaching on May 5th?
nifb01food
So by default all Cisco PIX / ASA configs have something along these lines...
policy-map type inspect dns migrated_dns_map_1
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect dns migrated_dns_map_1 <-- DNS inspection
so after May 5th, when DNSSEC is enabled on all root servers, I'd expect many quereies to be over the 512 byte maximum.  See http://www.theregister.co.uk/2010/04/13/dnssec/ if you are not familiar with this.
Does this mean I should change the 512 number to something else? suggestions on that? or should I just disable DNS inspection completely with: "no inspect dns"
18 Replies 18
Hey Troy,
pkampana is absolutely correct. You can keep the "message-length maximum 512" in, and just add the "message-length maximum client auto" line as per the bug.
Could you inform me in which version of FWSM is available the command "message-length maximum client auto"?
Thank you
Unfortunately the "auto" option is not available in FWSM.
You can only configure absolute maximum length but not "auto".
Here is the command for your reference:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm41/command/reference/i2.html#wp1639206
Hope that answers your question.
Thank you Jennifer for your prompt answer, i will try to increase the maximum length to 1536 bytes.
