Cisco PIX ASDM - Help
e.deangelis
Hi all,
i have a pix 515E and i try to configure access to ASDM tool.
This is my config:
http server enable
http 192.168.149.4 255.255.255.255 inside
I have tried to access at PIX address : https://192.168.149.3/startup.html
but after prompt login i received a error 404 from internet explorer.
WHY?
7 Replies 7
jmia
Level 7
Level 7
I presume, that the PC/Laptop that you are initiating the ASDM access from is IP 192.168.149.4?? As you have given access to the ASDM only from this IP.
Try changing the ASDM access to any client on the inside and see if this resolves your problem i.e.
http server enable
http 192.168.149.0 255.255.255.0 inside
Let me know how you get on.
Jay
i have tried to change configuration, but i received same error.
How to know if my pix supports asdm? How to know if asdm is installed into my pix?
Please help me!
Thanks a lot
Issue: sho ver
And post back the result - take out any sensitive info.
asdm works with pix v7 not v6.x.
when i was trying asdm, i type in https:///admin
also even asdm is not installed, pdm should still be there for v6.x.
This is my sh ver:
Cisco PIX Security Appliance Software Version 7.0(2)
Compiled on Fri 15-Jul-05 22:55 by builders
System image file is "flash:/pix702.bin"
Config file at boot was "startup-config"
IperPIX up 10 mins 22 secs
Hardware: PIX-515E, 128 MB RAM, CPU Pentium II 433 MHz
Flash E28F128J3 @ 0xfff00000, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
5)
0: Ext: Ethernet0 : address is 0009.b75f.857b, irq 10
1: Ext: Ethernet1 : address is 0009.b75f.857c, irq 11
Licensed features for this platform:
Maximum Physical Interfaces : 6
Maximum VLANs : 25
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Disabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : Unlimited
This platform has an Unrestricted (UR) license.
I have tried to connect at http://mypix/admin but i receiv only the request of certificate like ever and then error 404 Page not found.
I wait a response, please.
the problem seems to be that asdm is maybe not installed on ur pix.Chk via show flash command.U will also get to know abt whether pdm is installed in ur pix.
. Also chk whether u r able to open via normal HTTPS://x.x.x.x method.incase PDM is installed pls be sure abt jre version.
prchauha
Try the following and see if that resolves the issue:
1.) Issue "show version" command and see if ASDM v5.x is installed.
2.) If you see ASDM installed, then verify if you have specified it in the config:
Steps:
pixfirewall(config)#dir
This command would display all the contents in PIX Flash Filesystem. Make a note of ASDM filename and location.
pixfirewall(config)#asdm image flash:
pixfirewall(config)#http server enable
pixfirewall(config)#http 0 0 inside
After entering the above info try.
If this does'nt help open up a TAC Service Request.
Cheers...
Prashant Chauhan
